The Navigator icon The Navigator — Path-planning navigator using ARC NMS position and obstacle data to map, log trajectories, and autonomously follow waypoints. Try it →
Have you checked the fuse? Are you sure the battery is charged? I mean did you check the battery voltage with a multi meter?
Hi! Has he turned on before?
No I just got him and I put the ezb in and nothing happened after I turned him on.
@Theguitarguy.
Have you done the checks mentioned in post #2? If you're unsure how to check/replace the fuse in the power shell, there is a guide that shows you how to do so linked below,
Fuse Replacement
After you have done these couple of checks, as well as checking if the battery is connected properly, report back here with what you have tried, and we'll check for other possible solutions.
Thank you guys for helping! He works great now!
Excellent! Enjoy:D:D
