Task Script icon Task Script — Split complex robot tasks into sequential scripts, synchronizing asynchronous skills via NEXT/CANCEL commands for staged automation. Try it →
Jd - Jerky Movement
Hi,
I purchased the JD Humanoid kit four days ago. The first two days I built the robot, calibrated the servos, saved a servo profile, and started to play around with the functionality (movement, dances, Roboscratch) without any issues. I also connected through my Android device and created a profile for that.
The next two days I noticed the robot's movements became extremely jerky, especially when moving around (forward backward etc).
I checked the FAQ: The WiFi situation has not changed and the robot never disconnects from WiFi. I tried taking off the controller and plugging back in to the battery. I also checked the RGB cable is connected.
Is there something else I can try before I submit for warranty?
Thanks in advance for looking into this
Phil
Thanks for the response DJ. I created a new servo profile and that seems to have resolved the issue - will close this case
Cheers
Phil
