Servo Pad icon Servo Pad — Drag mouse or finger as a virtual joystick to control pan/tilt x- and y-axis servos with configurable ports, limits, inversion, and backgrounds. Try it →
Is There An Outside Area For Script In ARC That Can Keep An Eye On Blockly?
Is there an outside area for script in ARC that can keep an eye on Blockly and override it if necessary, rather than writing it in each Blockly script to avoid a certain scenario which amounts to a crash of the end effector. Hypothetical scenario: Swing the base of the robot 180 degrees but if the second arm is extended it will hit an obstruction at 130 degrees of rotation. If there were outside rules that could be stated beforehand in another overriding script or function it could make the proper adjustments on the fly to avoid the crash. The other script might say something like this: If the base is going towards 130 degrees lower the arm to 20% and after it gets past 150 degrees raise it back up to the original 80% extended. Any suggestions?
Script by Synthiam
In ARC, you can create a global script that monitors the state of your robot and takes action when certain conditions are met. This script can run in the background and act as a safety or override system for your Blockly scripts. To achieve this, you can use the Script skill to write an EZ-Script that continuously checks the position of your robot's base and arm and adjusts the arm's position if necessary.
Here's a hypothetical example of how you might set up such a script:
  1. Add a new Script skill to your ARC project (Project -> Add Skill -> Scripting -> Script).
  2. In the script editor, write a script that runs in a loop and monitors the base and arm positions. Use global variables to track the state of the robot's movements.
:Start
# Loop indefinitely
repeatForever()
  # Get the current position of the base and arm
  $basePosition = GetServo(D0) # Replace D0 with the actual port for the base servo
  $armPosition = GetServo(D1) # Replace D1 with the actual port for the arm servo
  # Check if the base is moving towards the obstruction angle
  if ($basePosition >= 130 and $basePosition < 150)
    # Lower the arm to avoid collision
    Servo(D1, 20) # Replace D1 with the actual port for the arm servo
  endif
  # Check if the base has passed the obstruction angle
  if ($basePosition >= 150)
    # Raise the arm back to the original position
    Servo(D1, 80) # Replace D1 with the actual port for the arm servo
  endif
  # Small delay to prevent high CPU usage
  sleep(100)
endrepeatForever
  1. Save the script and start it. This script will now run in the background and continuously monitor the positions of the base and arm.
  2. In your Blockly scripts, you can continue to command the robot as usual. The background script will take care of adjusting the arm's position when the base rotates towards the obstruction angle.
Remember to replace D0 and D1 with the actual servo ports you are using for the base and arm, respectively. Also, adjust the servo positions (20 and 80 in the example) to match the safe positions for your robot's arm.
By using this approach, you can create a centralized monitoring system within your ARC project that acts independently of your Blockly scripts, providing an additional layer of safety and control.
@Athena great answer and was what I was thinking, just didn't know how to do it. Thanks
You're welcome! I'm glad the information was helpful. If you have any more questions or need further assistance as you work on your project, feel free to reach out. Good luck with your robot, and have fun building and programming!
@Athena I see a bit of a conflict in your previous script when you have 2 scripts running at the same time. The first script will tell it to go to a position and then the oversee script will tell it to lower down which repeats at an interval of 100 ms. In the meantime for the other 99 ms the first script is still telling it to go to the original location. Is there a way to put a hierarchy on the scripts which would let the oversee script take over. Also when returning back to the intended location wouldn't that need to be put into a variable or remembered so it knows where to go. Could this be done with a  -1 or a 0 in Blockly whereas it allows it to go to that position and the oversee script doesn't step in to override it. Can you explain in detail about these scenarios.
You're correct that there could be a conflict if two scripts are trying to control the same servo simultaneously. To resolve this, you can use global variables as flags to indicate when the override should take control and when it should release control back to the main script.
Here's a more detailed approach to implementing a hierarchy and memory for the intended position:
  1. Define global variables to act as flags and to store the intended position of the arm.
# Initialize global variables at the start of your project
setVar($overrideActive, false)
setVar($intendedArmPosition, 80) # Default position or last known safe position
  1. Modify the overseeing script to check the flag and only take control when necessary. It should also remember the intended position.
:Start
repeatForever()
  if($basePosition >= 130 and $basePosition < 150 and !$overrideActive)
    # Activate override
    setVar($overrideActive, true)
  endif
  if($basePosition >= 150 and $overrideActive)
    # Deactivate override
    # Return the arm to the intended position
    Servo(D1, getVar($intendedArmPosition))
  endif
  sleep(100)
endrepeatForever
  1. In your main Blockly script (or any other script that moves the arm), check the $overrideActive flag before sending a move command. If the override is active, update the $intendedArmPosition variable instead of moving the arm directly.
# Example of moving the arm within a  Blockly script
if(!$overrideActive)
  Servo(D1, 80) # Move arm to position 80
else
  setVar($intendedArmPosition, 80) # Update intended position
endif
  1. For the scenario where you want the overseeing script not to step in, you can use the $overrideActive flag to control this behavior. If you set $overrideActive to true, the overseeing script will not attempt to override the arm position. You can then set it back to false when you want the overseeing script to resume its protective behavior.
By using this approach, you create a system where the overseeing script only takes control when necessary and remembers where the arm was supposed to go. Once the condition that triggered the override is cleared, the arm can return to its intended position. This method ensures that your scripts cooperate rather than conflict with each other.
