On Variable Changed icon On Variable Changed — Run scripts automatically when specified ARC variables change; define variable-to-script pairs, monitor status, and trigger actions. Try it →
Germany
Integrate Ez-B Dlls Into C++/Qt Application ?
Hi,
I would like to use Qt, which is C++ based, to write an application for controlling our little robot. Does anyone have any experience, how to integrate the EZ-B .NET DLLs into Qt ?
Or is there any other way how to do it (except changing the programming language, because we have a lot of tested/verified modules, which we would like to reuse) ? How about sending commands directly to the bluetooth interface ? Is such a low-level documentation available ?
Thank you for your help :)
Arne
Germany
Wow, that was a really fast and informative answer ! eek
Yes, i am using Qt for windows, therefore I will start using activeqt (and I am really curious...). I will post an update, if I was successful or need additional help.
Again thank you for your help !
