Servo Summary icon Servo Summary — All-in-one servo view showing and editing servo positions and speeds; add servos and resize the control to fit. Try it →
Hello @Nomad,
The tick you are hearing is the DAC initializing. If you change your code to have the speech be continuous instead of pausing between sentences you can stop the ticking. Ex:
SayEZB("I am a robot. I can speak. I am unique and can do many things!")
hi jer
whithout the dots then.cause he wil say dot.am stil hearing it in the begin&end.
#3   — Edited
@Nomad
The speech should pause when there is a period, you may have to delete the period and add a period that isn't copy and pasted. Sometimes between copying and pasting code the symbols can be misinterpreted. This happens to me when copying and pasting quotation marks for me in EZ-script. I have to delete the quotation marks and type them manually.
As for the tick at the beginning, I don't believe this can be helped. It's the DAC initializing.
ok whit the pauze it sounds better. thanks for the fast respons.
