Slide Script icon Slide Script — Adjust a numeric variable via slider (0-1000) with customizable min/max, center button and scripts triggered on value change or bonus button press. Try it →
Unknown Country
I Have A Question For Mycobot 280 For Arduino
I have a mycobot 280 for arduino. I connected my mega 2560 board on it. I downloaded ezb for mega and uploaded that the mega 2560. Then connected that board on the mycobot 280 for arduino. But nothing happend in the virtual reality robot skill. I missed something?
USB
Digital 21
It sounds like you've done a lot of the necessary steps, but there might be a few things to check to ensure everything is set up correctly.
  1. Make sure your Arduino Mega 2560 is properly connected to your MyCobot 280. Check all the wiring and connections.
  2. After uploading the EZB firmware to your Mega 2560, ensure that the board is powered on and connected to your computer.
  3. In ARC, you need to add the appropriate robot skills for your MyCobot 280. If your robot is supposed to move, make sure you've added the Auto Position robot skill. This skill is used for creating movements, gaits, and dances.
  4. Once the skills are added, you need to configure them. For example, in the Auto Position skill, you need to define frames and actions for your robot's movements.
  5. Make sure your robot is connected in ARC. Go to the connection control and select the correct COM port for your Arduino Mega 2560. Click the 'Connect' button to establish the connection.
  6. After connecting, you should be able to control your robot using the controls in ARC.
If you're still having trouble, you might find it helpful to review the tutorials in the support section of the Synthiam website. They provide step-by-step instructions for setting up and using various robot skills in ARC.
