How can I detect if sound is being played through the PC's sound card and then execute a script in Synthiam ARC? The Sound servo Skill doesn't seem to provide an option to trigger a script.
I'm looking for a way to monitor audio output and initiate a script based on sound activity. Any guidance on how to achieve this within the ARC environment would be appreciated.
To detect if sound is being played through the PC's sound card and execute a script in Synthiam ARC, you can use the Speech Script skill to monitor when speech is being played. However, if you want to monitor general audio output from the PC's sound card, you might need to use a workaround since ARC doesn't directly support monitoring all PC audio output.
Here's a step-by-step guide to achieve this using the Speech Script skill:
Add the Speech Script Skill:
Configure the Speech Script:
Script Start Speaking:
Script End Speaking:
Example Script:
Testing:
If you need to monitor general audio output from the PC's sound card, you might need to explore external solutions or software that can detect audio output and trigger actions in ARC through a different method, such as sending commands via a network or serial interface.
Feel free to ask if you have more questions or need further assistance!
@Athena Alas I need a script to monitor audio output from the PC's sound card that is not generated within ARC.
Monitoring audio output from the PC's sound card that is not generated within ARC directly through ARC is not natively supported. However, you can achieve this by using external software or scripts that can detect audio output and then communicate with ARC to trigger actions. Here's a general approach you can take:
Step-by-Step Guide
External Audio Monitoring Software:
pyaudioorsounddeviceto monitor audio levels.Script to Monitor Audio:
Write a script in Python (or another language) that uses the audio monitoring library to detect when sound is playing. Here's a basic example using Python and
sounddevice:Communicate with ARC:
Set Up ARC to Receive Commands:
Testing and Adjustments:
Additional Resources
This approach requires some programming and setup outside of ARC, but it allows you to monitor audio output from the PC's sound card and trigger actions in ARC based on that detection. If you have any questions or need further assistance, feel free to ask!
@Athena Thanks for the information albeit a complex solution. All that's really needed is a new Sound Script Skill based on the Sound servo Skill which does know when sound is being played through the PC's sound card.
Creating a new Sound Script Skill based on the Sound servo Skill to detect when sound is being played through the PC's sound card and execute a script is a great idea. While this feature isn't natively available in ARC, you can suggest it as a feature request to Synthiam. They might consider adding it in future updates if there's enough interest.
In the meantime, here's a conceptual approach to how such a skill could work:
Conceptual Approach for a Sound Script Skill
Sound Detection:
Script Execution:
Configuration Options:
Integration with ARC:
Suggesting the Feature
To suggest this feature to Synthiam, you can:
If you have any more questions or need further assistance, feel free to ask!
