Lidar-Lite Laser Module icon Lidar-Lite Laser Module — Laser Lidar-Lite ARC control reads distance, velocity and signal strength (0-40m+) via EZ-B v4 i2c, setting EZ-Script vars for robotics Try it →
Hi @Nomad
Under the controls tab at the top of ARC you can click the smart arrange button two times to get all the controls to pop to the top of the window.
Click on Smart Arrange to have ARC put all controls closer to each other.
For more screen real estate consider increasing your screen resolution or taking advantage of desktops 2 and 3 for some controls.
Both are in the menu ribbon, I am on an XP PC at the moment so can't give screenshots but you should see them if you cycle through the tabs on the ribbon along the top.
thank you jeremie double click worked.
also thank you rich for answering.
That's what I do... Desktop 1 quickly gets cluttered so I use desktop screen 2 and sometimes 3 a lot...
