google for the "firefly" user manual. The procedure and commands will be in the manual.
No, do not attempt to modify the Bluetooth module by using any internet manual - or you will damage the module
  1. Load ARC
  2. Connect to your EZ-B
  3. Press Add Control
  4. Select GENERAL tab
  5. Select EZ-B Configuration control
  6. Select Read Configuration From EZ-B
  7. Press SET
  8. Enter new Bluetooth name
  9. Press Save To Ez-B
  10. Reset the power on your EZ-B
