yup ive seen this but thanks . opps i found where setting that i wanted to change cool hope work thanks man.:D
I believe DJ has provided a servo center script in the Examples under building a boxbot:)
yes its in box bot i can change setting only works for centering or i call home postion . then going to set program for vert postion for servo move it manual key board then move home it goes back to orig postion to 50 .The other platform i can change that home postion setting due sometimes servo horns groves are off just little not all perfect.:D
