Vertical Servo icon Vertical Servo — Drag vertically to control a servo within set min/max limits; center, release, invert, and mirror to other servos. For 3-wire GVS servos. Try it →
Israel
Hello,I'm Trying To Play An
Hello, I'm trying to play an audio (I'm coding in C# SDK)
I converted .mp3 to raw by audio conversion software, and when i play the .raw on audacity is sounds pretty fine
I tried to use _ezb.SoundV4.PlayData function like this:
byte[] bytes = File.ReadAllBytes("../path");
_ezb.SoundV4.PlayData(bytes,100);
 but the audio sounds really bad
when i try to play the .mp3 in ARC it sounds better.
any ideas? thank you!
#1   — Edited
Must save PCM as MONO 8 BIT and 14700 hz
I recommend loading and playing the file in real-time like this... Here's how the soundboard loads and plays the file. I compress the file so it can be stored in a much smaller memory footprint
if (openFileDialog1.FileName.ToLower().Contains(".mp3")) {
  using (NAudio.Wave.Mp3FileReader mp3 = new NAudio.Wave.Mp3FileReader(openFileDialog1.FileName)) {
    using (NAudio.Wave.WaveFormatConversionStream pcm = new NAudio.Wave.WaveFormatConversionStream(new NAudio.Wave.WaveFormat(EZ_B.EZBv4Sound.AUDIO_SAMPLE_BITRATE, 8, 1), mp3)) {
      using (MemoryStream ms = new MemoryStream()) {
        using (GZipStream gz = new GZipStream(ms, CompressionMode.Compress))
          pcm.CopyTo(gz);
        _compressedAudioArray = ms.ToArray();
} else if (openFileDialog1.FileName.ToLower().Contains(".wav")) {
  using (NAudio.Wave.WaveStream wav = new NAudio.Wave.WaveFileReader(openFileDialog1.FileName)) {
    using (NAudio.Wave.WaveFormatConversionStream pcm = new NAudio.Wave.WaveFormatConversionStream(new NAudio.Wave.WaveFormat(EZ_B.EZBv4Sound.AUDIO_SAMPLE_BITRATE, 8, 1), wav)) {
          pcm.CopyTo(gz);
} else {
  throw new Exception("Unsupported audio file type.");
Playback like this...
using (MemoryStream ms = new MemoryStream(_compressedAudioArray))
using (GZipStream gz = new GZipStream(ms, CompressionMode.Decompress))
  EZBManager.EZBs[_cf.SoundBoardv4.EZBIndex].SoundV4.PlayData(gz, 100);
Israel
It worked! Thank you very much!
