EZB Connection icon EZB Connection — Connects EZ-B I/O controllers to ARC via COM or IP (5 connections). Supports init scripts, battery monitoring, TCP/EZ-Script server and serial/I2C. Try it →
Hard Drive Access?
Is there any way to read or write to a hard drive within the ARC?
I wrote a MS Kinect software application that writes Kinect date to text files and updates them in real time. (I call it the "painless data exchange protocol.")
It would be really great if I could get Kinect data into ARC.
If not directly, does ARC have the ability to run
I think i figured it out :
Dim textStuff As string
textStuff = My.Computer.FileSystem.ReadAllText("C:\Users\Thomas\Desktop\stuff.txt")
Are you using the VB Scripting control? That'll be your best friend for custom scripting:)
Yup, I am using the VB scripting control.
Now that I have the data in a VB scripting control, how do I pass the info on to an EZ Script window? Is there an equivalent to the "ControlCommand( windowName, windowControlCommand )" that I can run from the VB scripting control? Are there global variables that can be access from the EZ script controls?
