Serial Terminal icon Serial Terminal — PC and EZB serial terminals for ARC: connect, monitor and send text/ASCII to serial devices. Supports COM, flow control, baud, DTR/RTS, hex Try it →
It really depends what you're going to hook up to the EZ-B. Have a read of this section if my power supply tutorial. There's also a detailed battery section as well. It should hopefully tell you everything you need to know. Bottom line is, if your connecting servos to the EZ-B, you will need a supply with a high amp output depending on what you have connected, and a voltage output between 4.5v and 16v.
