Smart Variable Watcher icon Smart Variable Watcher — Efficient ARC Variable Watcher - lower CPU for large projects; slow initial array render but faster updates; shows name, type, value, length Try it →
Ezb V$ And Camera Dimensions?
I did a quick search but could not find anything on the dimensions for both the ezb V4 and the new camera un-housed. Is there a schematic floating around that has already been posted? I need it to make modifications. In particular I need a side view and measurements of the side view of the camera and pcb its attached to. Thanks in advance to any links or info.
Edit, dang cant change the typo in subject field!
Even something as simple as a phone pic looking straight down at the camera and dimensions marked up with in a photoshop like program on the pic. Most important are the dimension from the top edge to the center lens, also from the sides, and the outside diameter of the plastic circle around the lens, and how much the lens sticks out from the pcb. And really need the dimension of the outer lens shell, the black disk surrounding the lens.
Thanks!
Sure could use a mark up on the camera. Do you have side ways dimmensions, looking at the pcb and camera sideways, depth of camera lens to back of the back pcb. Thanks
