Wii Remote icon Wii Remote — Control servos, movement panels and scripts via Wii Remote or mobile accelerometer; D-pad, buttons and Home-enabled accelerometer tracking. Try it →
Ez-Script Reference Manual
If like me, you will play around with script ideas when you shouldn't be (i.e. at work). Rather than install ARC to get the EZ-Script commands I decided to "print" the EZ-Script manual to PDF so I can view it at work this way.
If it's of any use to you I've uploaded it to some of my webspace so anyone can download it from here (release 2013.03.13.00)
Note: EZ-Script may be updated and commands added, removed or changed at any time therefore the PDF manual may not always be up to date. Always check against the latest release of ARC. I will do my best to keep it up to date but it is not always possible.
Excellent idea!
Thanks.
Thanks @jstarne1, this is one for the WiKi!
Spain
That's great RichMR2! but there is something that I believe is not in the original manual and are the key commands to copy, cut, paste fragments or whole scripts from one site to another. right click does not work for this and that this was discussed long ago in some thread. (which I find by the way) Could someone refresh my memory with key commands (copy, cut, paste) Thanks!
Ctrl & x to cut Ctrl & c to copy Ctrl & v to paste
Spain
Thanks RichMR2, this has been very helpful for me, now I can copy scripts to other projects and duplicate sequences within the same script, greetings.
Good idea Rich. However now there is a new upgrade and your manual is out of date. blush
I stopped doing this a few months ago. With all the upgrades DJ does my list didn't help much anymore.
However as a quick reference as your writing scripts having an up to date printed list sitting there at your side is very helpful! :)
There really needs to be a community maintainable wiki for this. No reason the burden should just be on you @RichMR2 but thank you anyways. Also, one tip. Add a last version number at the header and a last update date as well.
Josh is setting up a Wiki for EZ Robot along with his other long list of projects that are in the works. Maybe he can add this to the setup and make just this section community maintainable?
