Hello DJ Sures,
Me again, I just had a quick question about what batteries you can use with the EZ-B. Can you use any Li-Po battery aslong as it is under 9v? If so, what would you suggest?
Thanks, Joshua
Hello DJ Sures,
Thanks, Joshua
The ez robot servos are probably good for up tp 8.4v the ezb4 itself can do anything from about 5V to 16V or so... Saying that if you use any voltage above the recommend servo voltage you will most definitely destroy them...
