EZ-B V3 Configuration icon EZ-B V3 Configuration — Manage EZ-B hardware settings: edit Bluetooth name and apply updates to restore altered configurations. Try it →
Resolved Resolved by edison2!
Errors With Attempting To Work With The Kit Using Vb2010.
I need help with the following errors. the Bluetooth device has assigned com 8 to the ez board.
Warning 1 The primary reference "EZ_B" could not be resolved because it has an indirect dependency on the .NET Framework assembly "mscorlib, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089" which has a higher version "4.0.0.0" than the version "2.0.0.0" in the current target framework. VB - Tutorial 01 - servo Move Warning 2 The primary reference "EZ_B" could not be resolved because it has an indirect dependency on the .NET Framework assembly "System, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089" which has a higher version "4.0.0.0" than the version "2.0.0.0" in the current target framework. VB - Tutorial 01 - servo Move Warning 3 The primary reference "EZ_B" could not be resolved because it has an indirect dependency on the .NET Framework assembly "System.Windows.Forms, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089" which has a higher version "4.0.0.0" than the version "2.0.0.0" in the current target framework. VB - Tutorial 01 - servo Move Warning 4 The primary reference "EZ_B" could not be resolved because it has an indirect dependency on the .NET Framework assembly "System.Xml, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089" which has a higher version "4.0.0.0" than the version "2.0.0.0" in the current target framework. VB - Tutorial 01 - servo Move Warning 5 The primary reference "EZ_B" could not be resolved because it has an indirect dependency on the .NET Framework assembly "System.Drawing, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a" which has a higher version "4.0.0.0" than the version "2.0.0.0" in the current target framework. VB - Tutorial 01 - servo Move Warning 6 The primary reference "EZ_B" could not be resolved because it has an indirect dependency on the .NET Framework assembly "System.Speech, Version=4.0.0.0, Culture=neutral, PublicKeyToken=31bf3856ad364e35" which has a higher version "4.0.0.0" than the version "3.0.0.0" in the current target framework. VB - Tutorial 01 - servo Move Warning 7 The primary reference "EZ_B" could not be resolved because it has an indirect dependency on the .NET Framework assembly "WindowsBase, Version=4.0.0.0, Culture=neutral, PublicKeyToken=31bf3856ad364e35" which has a higher version "4.0.0.0" than the version "3.0.0.0" in the current target framework. VB - Tutorial 01 - servo Move Warning 8 The primary reference "EZ_B" could not be resolved because it has an indirect dependency on the .NET Framework assembly "PresentationCore, Version=4.0.0.0, Culture=neutral, PublicKeyToken=31bf3856ad364e35" which has a higher version "4.0.0.0" than the version "3.0.0.0" in the current target framework. VB - Tutorial 01 - servo Move Warning 9 The primary reference "EZ_B" could not be resolved because it has an indirect dependency on the .NET Framework assembly "System.Core, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089" which has a higher version "4.0.0.0" than the version "3.5.0.0" in the current target framework. VB - Tutorial 01 - servo Move Warning 10 The primary reference "EZ_B" could not be resolved because it has an indirect dependency on the .NET Framework assembly "System.Configuration, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a" which has a higher version "4.0.0.0" than the version "2.0.0.0" in the current target framework. VB - Tutorial 01 - servo Move Warning 11 The primary reference "EZ_B" could not be resolved because it has an indirect dependency on the .NET Framework assembly "System.Security, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a" which has a higher version "4.0.0.0" than the version "2.0.0.0" in the current target framework. VB - Tutorial 01 - servo Move Warning 12 The primary reference "EZ_B" could not be resolved because it has an indirect dependency on the .NET Framework assembly "Accessibility, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a" which has a higher version "4.0.0.0" than the version "2.0.0.0" in the current target framework. VB - Tutorial 01 - servo Move Warning 13 The primary reference "EZ_B" could not be resolved because it has an indirect dependency on the .NET Framework assembly "System.Runtime.Serialization.Formatters.Soap, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a" which has a higher version "4.0.0.0" than the version "2.0.0.0" in the current target framework. VB - Tutorial 01 - servo Move Warning 14 The primary reference "EZ_B" could not be resolved because it has an indirect dependency on the .NET Framework assembly "System.Deployment, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a" which has a higher version "4.0.0.0" than the version "2.0.0.0" in the current target framework. VB - Tutorial 01 - servo Move Warning 15 The primary reference "EZ_B" could not be resolved because it has an indirect dependency on the .NET Framework assembly "System.Data.SqlXml, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089" which has a higher version "4.0.0.0" than the version "2.0.0.0" in the current target framework. VB - Tutorial 01 - servo Move Warning 16 The primary reference "EZ_B" could not be resolved because it has an indirect dependency on the .NET Framework assembly "Microsoft.VisualC, Version=10.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a" which has a higher version "10.0.0.0" than the version "8.0.0.0" in the current target framework. VB - Tutorial 01 - servo Move Warning 17 The primary reference "EZ_B" could not be resolved because it has an indirect dependency on the framework assembly "System.Xaml, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089" which could not be resolved in the currently targeted framework. ".NETFramework,Version=v3.5". To resolve this problem, either remove the reference "EZ_B" or retarget your application to a framework version which contains "System.Xaml, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089". VB - Tutorial 01 - servo Move Warning 18 The primary reference "EZ_B" could not be resolved because it has an indirect dependency on the .NET Framework assembly "System.Xml.Linq, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089" which has a higher version "4.0.0.0" than the version "3.5.0.0" in the current target framework. VB - Tutorial 01 - servo Move Warning 19 The primary reference "EZ_B" could not be resolved because it has an indirect dependency on the .NET Framework assembly "System.Data, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089" which has a higher version "4.0.0.0" than the version "2.0.0.0" in the current target framework. VB - Tutorial 01 - servo Move Warning 20 The primary reference "EZ_B" could not be resolved because it has an indirect dependency on the .NET Framework assembly "UIAutomationProvider, Version=4.0.0.0, Culture=neutral, PublicKeyToken=31bf3856ad364e35" which has a higher version "4.0.0.0" than the version "3.0.0.0" in the current target framework. VB - Tutorial 01 - servo Move Warning 21 The primary reference "EZ_B" could not be resolved because it has an indirect dependency on the .NET Framework assembly "UIAutomationTypes, Version=4.0.0.0, Culture=neutral, PublicKeyToken=31bf3856ad364e35" which has a higher version "4.0.0.0" than the version "3.0.0.0" in the current target framework. VB - Tutorial 01 - servo Move Warning 22 The primary reference "EZ_B" could not be resolved because it has an indirect dependency on the framework assembly "System.Windows.Input.Manipulations, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089" which could not be resolved in the currently targeted framework. ".NETFramework,Version=v3.5". To resolve this problem, either remove the reference "EZ_B" or retarget your application to a framework version which contains "System.Windows.Input.Manipulations, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089". VB - Tutorial 01 - servo Move Warning 23 The primary reference "EZ_B" could not be resolved because it has an indirect dependency on the framework assembly "System.Numerics, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089" which could not be resolved in the currently targeted framework. ".NETFramework,Version=v3.5". To resolve this problem, either remove the reference "EZ_B" or retarget your application to a framework version which contains "System.Numerics, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089". VB - Tutorial 01 - servo Move Warning 24 The primary reference "EZ_B" could not be resolved because it has an indirect dependency on the .NET Framework assembly "System.Runtime.Serialization, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089" which has a higher version "4.0.0.0" than the version "3.0.0.0" in the current target framework. VB - Tutorial 01 - servo Move Warning 25 The primary reference "EZ_B" could not be resolved because it has an indirect dependency on the .NET Framework assembly "System.Transactions, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089" which has a higher version "4.0.0.0" than the version "2.0.0.0" in the current target framework. VB - Tutorial 01 - servo Move Warning 26 The primary reference "EZ_B" could not be resolved because it has an indirect dependency on the .NET Framework assembly "System.EnterpriseServices, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a" which has a higher version "4.0.0.0" than the version "2.0.0.0" in the current target framework. VB - Tutorial 01 - servo Move Warning 27 The primary reference "EZ_B" could not be resolved because it has an indirect dependency on the framework assembly "System.Runtime.DurableInstancing, Version=4.0.0.0, Culture=neutral, PublicKeyToken=31bf3856ad364e35" which could not be resolved in the currently targeted framework. ".NETFramework,Version=v3.5". To resolve this problem, either remove the reference "EZ_B" or retarget your application to a framework version which contains "System.Runtime.DurableInstancing, Version=4.0.0.0, Culture=neutral, PublicKeyToken=31bf3856ad364e35". VB - Tutorial 01 - servo Move Warning 28 The primary reference "EZ_B" could not be resolved because it has an indirect dependency on the .NET Framework assembly "System.DirectoryServices, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a" which has a higher version "4.0.0.0" than the version "2.0.0.0" in the current target framework. VB - Tutorial 01 - servo Move Warning 29 The primary reference "EZ_B" could not be resolved because it has an indirect dependency on the .NET Framework assembly "System.Runtime.Remoting, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089" which has a higher version "4.0.0.0" than the version "2.0.0.0" in the current target framework. VB - Tutorial 01 - servo Move Warning 30 The primary reference "EZ_B" could not be resolved because it has an indirect dependency on the .NET Framework assembly "System.Web, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a" which has a higher version "4.0.0.0" than the version "2.0.0.0" in the current target framework. VB - Tutorial 01 - servo Move Warning 31 The primary reference "EZ_B" could not be resolved because it has an indirect dependency on the .NET Framework assembly "Microsoft.Build.Framework, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a" which has a higher version "4.0.0.0" than the version "3.5.0.0" in the current target framework. VB - Tutorial 01 - servo Move Warning 32 The primary reference "EZ_B" could not be resolved because it has an indirect dependency on the framework assembly "System.Runtime.Caching, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a" which could not be resolved in the currently targeted framework. ".NETFramework,Version=v3.5". To resolve this problem, either remove the reference "EZ_B" or retarget your application to a framework version which contains "System.Runtime.Caching, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a". VB - Tutorial 01 - servo Move Warning 33 The primary reference "EZ_B" could not be resolved because it has an indirect dependency on the framework assembly "System.Web.ApplicationServices, Version=4.0.0.0, Culture=neutral, PublicKeyToken=31bf3856ad364e35" which could not be resolved in the currently targeted framework. ".NETFramework,Version=v3.5". To resolve this problem, either remove the reference "EZ_B" or retarget your application to a framework version which contains "System.Web.ApplicationServices, Version=4.0.0.0, Culture=neutral, PublicKeyToken=31bf3856ad364e35". VB - Tutorial 01 - servo Move Warning 34 The primary reference "EZ_B" could not be resolved because it has an indirect dependency on the .NET Framework assembly "System.Web.Services, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a" which has a higher version "4.0.0.0" than the version "2.0.0.0" in the current target framework. VB - Tutorial 01 - servo Move Warning 35 The primary reference "EZ_B" could not be resolved because it has an indirect dependency on the framework assembly "Microsoft.Build.Utilities.v4.0, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a" which could not be resolved in the currently targeted framework. ".NETFramework,Version=v3.5". To resolve this problem, either remove the reference "EZ_B" or retarget your application to a framework version which contains "Microsoft.Build.Utilities.v4.0, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a". VB - Tutorial 01 - servo Move Warning 36 The primary reference "EZ_B" could not be resolved because it has an indirect dependency on the .NET Framework assembly "System.DirectoryServices.Protocols, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a" which has a higher version "4.0.0.0" than the version "2.0.0.0" in the current target framework. VB - Tutorial 01 - servo Move Warning 37 The primary reference "EZ_B" could not be resolved because it has an indirect dependency on the .NET Framework assembly "System.Design, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a" which has a higher version "4.0.0.0" than the version "2.0.0.0" in the current target framework. VB - Tutorial 01 - servo Move Warning 38 The primary reference "EZ_B" could not be resolved because it has an indirect dependency on the framework assembly "Microsoft.Build.Tasks.v4.0, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a" which could not be resolved in the currently targeted framework. ".NETFramework,Version=v3.5". To resolve this problem, either remove the reference "EZ_B" or retarget your application to a framework version which contains "Microsoft.Build.Tasks.v4.0, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a". VB - Tutorial 01 - servo Move Warning 39 The primary reference "EZ_B" could not be resolved because it has an indirect dependency on the .NET Framework assembly "System.ServiceProcess, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a" which has a higher version "4.0.0.0" than the version "2.0.0.0" in the current target framework. VB - Tutorial 01 - servo Move Warning 40 The primary reference "EZ_B" could not be resolved because it has an indirect dependency on the .NET Framework assembly "System.Web.RegularExpressions, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a" which has a higher version "4.0.0.0" than the version "2.0.0.0" in the current target framework. VB - Tutorial 01 - servo Move Warning 41 The primary reference "EZ_B" could not be resolved because it has an indirect dependency on the .NET Framework assembly "System.Drawing.Design, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a" which has a higher version "4.0.0.0" than the version "2.0.0.0" in the current target framework. VB - Tutorial 01 - servo Move Warning 42 The primary reference "EZ_B" could not be resolved because it has an indirect dependency on the .NET Framework assembly "System.Data.OracleClient, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089" which has a higher version "4.0.0.0" than the version "2.0.0.0" in the current target framework. VB - Tutorial 01 - servo Move Warning 43 The primary reference "EZ_B" could not be resolved because it has an indirect dependency on the .NET Framework assembly "System.Configuration.Install, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a" which has a higher version "4.0.0.0" than the version "2.0.0.0" in the current target framework. VB - Tutorial 01 - servo Move Warning 44 The designer cannot process the code at line 25:
Me.EzB_Connect1 = New EZ_B.EZB_Connect
The code within the method 'InitializeComponent' is generated by the designer and should not be manually modified. Please remove any changes and try opening the designer again. C:\Users\James Few\Downloads\EZ-B SDK Windows\EZ-SDK\VB\VB - Tutorial 01 - servo Move\Form1.Designer.vb 26 0 Error 45 Type 'EZ_B.EZB_Connect' is not defined. C:\Users\James Few\Downloads\EZ-B SDK Windows\EZ-SDK\VB\VB - Tutorial 01 - servo Move\Form1.Designer.vb 26 31 VB - Tutorial 01 - servo Move Error 46 Type 'EZ_B.EZB_Connect' is not defined. C:\Users\James Few\Downloads\EZ-B SDK Windows\EZ-SDK\VB\VB - Tutorial 01 - servo Move\Form1.Designer.vb 81 39 VB - Tutorial 01 - servo Move Error 47 'EZ_B' is not declared. It may be inaccessible due to its protection level. C:\Users\James Few\Downloads\EZ-B SDK Windows\EZ-SDK\VB\VB - Tutorial 01 - servo Move\Form1.vb 6 29 VB - Tutorial 01 - servo Move Error 48 'EZ_B' is not declared. It may be inaccessible due to its protection level. C:\Users\James Few\Downloads\EZ-B SDK Windows\EZ-SDK\VB\VB - Tutorial 01 - servo Move\Form1.vb 7 29 VB - Tutorial 01 - servo Move Error 49 'EZ_B' is not declared. It may be inaccessible due to its protection level. C:\Users\James Few\Downloads\EZ-B SDK Windows\EZ-SDK\VB\VB - Tutorial 01 - servo Move\Form1.vb 8 27 VB - Tutorial 01 - servo Move Error 50 'EZ_B' is not declared. It may be inaccessible due to its protection level. C:\Users\James Few\Downloads\EZ-B SDK Windows\EZ-SDK\VB\VB - Tutorial 01 - servo Move\Form1.vb 14 49 VB - Tutorial 01 - servo Move Error 51 'EZ_B' is not declared. It may be inaccessible due to its protection level. C:\Users\James Few\Downloads\EZ-B SDK Windows\EZ-SDK\VB\VB - Tutorial 01 - servo Move\Form1.vb 19 88 VB - Tutorial 01 - servo Move stress stress stress stress
Windows 8.1 patch resolved issue for the blue tooth. I went with the GUI version and wrote a basic script to play mp3 file when executed.
