Sound Script icon Sound Script — Replaced by Sound Script (Speech Script) robot skill; see Synthiam's Speech Script support page. Try it →
EZB control from Android tablet
EZB Control From Android Tablet
I had hoped to control my robotic device with an android tablet.  I tried to download the ARC mobile version on my android 12 tablet through GooglePlay but was greeted with an error message that my tablet was not supported since the app was designed for an earlier android version.  Am I out of luck . . or maybe doing something wrong?  Thanks.
Craig
#17
Hello Nomad 6R. The project is saved on my PC.
Here is my panel.  Compare it to yours.  Everything is identical except you have four choices Design, Port Summary, Thumbnail, and REM UI.  You have checked REM UI and your project has appeared in the window.  My panel has only three choices Design, Port Summary, and Thumbnail.  NOTE that there is no REM UI choice.  That is the problem.
seigezapf, Looks like we posted at the same time. Please see my post above yours.
In addition, I think you can purchases help from Synthiam Customer Support for about $10 and probably get a quick answer. However I feel out guess about you needing the Pro version that we both mentioned above is correct.
i would saved in the cloud too .  then remove ARC complete from your pc .reboot and redownload . as dave says the pro version is great no limits .
#20
Thank you Dave.  I think your guess is what is happening.  Right now my robotic arm project is just something I am fiddling around with on the side.  It is something I started 9 years ago then put it on the shelf until now.  If I were to become more involved in robotics, especially if I were to start programming,  I would consider the PRO subscription.  Thank you for taking the time to explain how I might work that out with Pro and Runtime.
Back in 2014 I had several conversations about my robotic arm with a friend who is much more programming savvy than me.  He mentioned arduino as something I might explore.  At that time I found EZ-Robot to be something I could use that matched my fledgling competence.  These days EZ-Robot is seeming more opaque to me. I have run into one conundrum after another.  I think the EZ-Robot tutorials would be more useful if I had the correct (Pro) version.  Or it may be a diminishing of my mental acuity with age.  I hope not.  I'm going to take a look at arduino (and raspberry pi), though I'm guessing it will not be more understandable for me than EZ-Robot.
Craig
#21
Thanks Nomad 6R.  Unfortunately I have no idea how I would save to the cloud rather than to my PC.  That may also be something that is only available in PRO.  I believe I will have to work with what I have unless I decide to update.
Craig
you can try it to save in the cloud . see #post 5 .next to SAVE AS  you see save cloud .if you dont save in the cloud am gessing you will not see your project on your mobile . also delete browser hystory before reboot pc .  if you have many try's from downloading . that can cause problems to .
btw dont say many times thanks .ones is enought .xD
seigezapf
ah .dave was correct then about the pro version .you can take a monthly decription .
