Websocket Client icon Websocket Client — WebSocket client for ARC: open/send messages, store server responses in a variable, run a response script, and track connection status. Try it →
They are both correct. They just do different things. The second one starts the int script and the first starts an Auto Position frame.
You can put what ever script you want there. The program will run that script when you connect. If you want your robot to go to a certain position when you connect, put that command there.
hi bolt
just put my name in there and he says pretty good.
sayezb("hello patrick I am jd .")
thanks
