Rubik's Cube Solving Robot icon Rubik's Cube Solving Robot — Control a custom ARC robot to manipulate and solve a Rubik's Cube using calibrated arms and grippers; integrates with Thingiverse build. Try it →
Resolved Resolved by Athena!
Connection Diagnostic Skill Functionality
I have a question about the ARC robot skill called Connection Diagnostic. Does this skill monitor the connection of only the EZB at index 0, or can it manage other indices as well?
Diagnose EZ-B Wi-Fi connection issues with verbose EZ-B communication logging, ping tests, log export and diagnostic reports for Synthiam support.
EZB Connections by Synthiam
Add and manage up to 255 EZ-B I/O controller connections in ARC, select COM/IP ports or device addresses to connect or remove devices.
Short answer: The Connection Diagnostic skill only monitors the project's primary/first Connection (the default EZ-B connection - connection index 0 / the main Connection control). It is a diagnostic tool for that primary connection (it uses the 192.168.1.1 ping/diagnostic flow), not a multiEZB monitor for other connection indices.
Details & options
Quick script to check an EZB IP (run in a JavaScript script control)
try {
  var resp = Net.hTTPGet("http://192.168.1.123";, 2000); // 2000 ms timeout
  print("Reachable, response length: " + resp.length);
} catch (e) {
  print("Not reachable or error: " + e);
  • Replace 192.168.1.123 with the EZB IP you want to test.
  • Use print() (not console.log()) per ARC scripting conventions.
How to run/configure Connection Diagnostic (if you need step-by-step)
  1. Project -> Add robot skill -> General -> Connection Diagnostic.
  2. Open the skill window and press the "Ping EZB" button (it pings 192.168.1.1 and displays the result).
  3. Open any skill settings via the three-line kebab (hamburger) menu in the robot skill window to review options.
Would you like me to:
  • Walk you through temporarily swapping which EZB is index 0?
  • Help make a small script to periodically monitor a particular EZB index or IP and log results? If so, tell me the EZB index or IP and whether it’s AP or client mode.
Great - glad it helped!
If you want, I can:
  • Walk you step-by-step to temporarily make another EZ-B the primary (index 0) for diagnostics, or
  • Provide a small JavaScript script (uses print()) to monitor an EZ-B IP or connection index periodically and log results.
Tell me which you'd prefer and the EZ-B IP or connection index and whether it’s in AP or Client mode.
