Sharp IR Radar icon Sharp IR Radar — Radar-style Sharp IR scanner for EZB ADC: sweeps sensor, displays distance dots, logs ADC voltage, and can steer/avoid obstacles via Movement Panel Try it →
Connecting to Six's Wi-Fi
Connecting To Six's Wi-Fi
Hi does anyone know why the Six Hexapod might not be connecting to a computer? I've put a new, working battery in the robot. When it turns on, there is no botting up noise and also doesn't flash blue but instead stays green before saying "I am unable to connect to your network". After that the light remains red. If anyone can help, that would be greatly appreciated, thank you.
Six Hexapod by EZ-Robot
Synthiam ARCx controls Six Hexapod with Auto Position gaits, joystick, voice, AI, vision tracking, and browser access.
#1   — Edited
Well, if it is an Ezbv4 there is a reset pin hole at the top you can try a hard reset and see if it can connect to robot or Wi fi router,you may need to go to client mode web site for EZ robot to put back your Router name and password.Usually the pin hole reset should have a connection to robot right away since EZB has it's own server connection to robot.Look for EZBv4 to show up on your P.C.or lap top and you can connect directly with Ezb.
That fixed it right up. Thank you DJ Sures and robo rad for your help.
Thank you for the help.
