Debug icon Debug — Central ARC debug window routing logs; shows UTC date/time, Windows/ARC/skill/hardware info, version/settings, with copy and clear. Try it →
Hi Djcaan from uk living in osaka japan can I ask is the ez-b v4 robot controller compatible with 2.4 ghz remote controls units I have a turnigy 9 channel transmitter and receiver if it is compatible I will by this ez-b v4 Any help is most welcomed and will be returned in kind if I can help anyone
Regards
mr djsures you say the The EZ-B v4 cant read Pwm the picture of it on this site says it can, if it really cant read PWM i respectfully suggest you ask your staff to change the picture just in case you get unhappy customers requesting refunds for items being advertised under false pretence. im making a robot dog from a uk tv show called doctor who the robot is called k9 . i like most of the stuff on your site and im looking for to use some of it in this model robot he is not a small robot her pretty big 3 feet in length 2 feet high and 18 inches wide maybe more the ears neck tail and lights require robotic parts to work along with electric motors 2x12 volt batteries
any way thanks for your original response
regards DJ caan
Just a shot in the dark here. Could you be confusing reading PWM with controlling PWM?
