TCP Clients icon TCP Clients — Monitor incoming TCP Server connections when TCP Server is enabled under Connection > Config; view and track live connections. Try it →
Combining Ezb Programs
Hey DJ, or anyone else..... Need a lil help here, Using the EZB software, is there an easy way to combine bits and pieces from different programs to into one larger program? What I want to do is this; I created a small program using the RGB Animator. I also created another program that runs a Arlo mobile base. I also created another program that operated multiple ultrasonic sensors. So now, I want to basically merge all three seperate programs to create a fourth program that contains all the elements of the three into just one. Id like to be able to cut and paste or whatever these other programs into one without hopefully having to retype and/or re-click everything all over again. Dont want to make extra work for myself if I don't have to.
Thoughts,ideas,comment?
confused;)
Use the "merge" function in the file menu...
Awesome, Thank you. I never really noticed that function before. nice.
