Neopixel Ring icon Neopixel Ring — ARC UI for onboard computers to control NeoPixel rings via serial: test/run patterns, preview and copy Arduino serial commands, includes sample code. Try it →
Germany
Can I See How Strong Is The Wifi Signal?
I have try to find a answer for my qestion.
When i use my robot outside from my house, the robot disconnect. Now i use a extra WIFI Dongle. But how far i can go?
Gives a script or a option for display the signal strenth?
And my second question is, how i can change the EZB from Clientmode to AP Mode back with the Webserver? I have the Settingsite and i have change this. I have try this 10 times. All times i become display saved.
After reboot, the Clientmode is always back.
I can only reset this setting for press the Resetbutton on the EZB. But for this, i must oben the Cover.
Thanks for your service
I highly recommend fixing your robot project. It is full of hundreds of errors. The status bar at the bottom of your screen must be displaying errors constantly, that you're ignoring. This is why ARC is unstable for your application...
Fix the errors and your software will be stable.
24.03.2017 10:05:58C:\Users\Stiko\Documents\EZ-Builder\My Projects\EZRI.EZBControl named 'Script Manager' does not exist. Can not send command 'ScriptStopAll'. 24.03.2017 10:05:58C:\Users\Stiko\Documents\EZ-Builder\My Projects\EZRI.EZBControl named 'Robot Dancing Music' does not exist. Can not send command 'stop'. 24.03.2017 10:05:58C:\Users\Stiko\Documents\EZ-Builder\My Projects\EZRI.EZBControl named 'Rear Arm' does not exist. Can not send command 'AutoPositionStop'. 24.03.2017 10:05:58C:\Users\Stiko\Documents\EZ-Builder\My Projects\EZRI.EZBControl named 'Front Arm' does not exist. Can not send command 'AutoPositionStop'. 24.03.2017 10:06:41C:\Users\Stiko\Documents\EZ-Builder\My Projects\EZRI.EZBControl named 'Script Manager' does not exist. Can not send command 'ScriptStopAll'. 24.03.2017 10:06:41C:\Users\Stiko\Documents\EZ-Builder\My Projects\EZRI.EZBControl named 'Robot Dancing Music' does not exist. Can not send command 'stop'. 24.03.2017 10:06:41C:\Users\Stiko\Documents\EZ-Builder\My Projects\EZRI.EZBControl named 'Rear Arm' does not exist. Can not send command 'AutoPositionStop'. 24.03.2017 10:06:41C:\Users\Stiko\Documents\EZ-Builder\My Projects\EZRI.EZBControl named 'Front Arm' does not exist. Can not send command 'AutoPositionStop'. 24.03.2017 10:07:01C:\Users\Stiko\Documents\EZ-Builder\My Projects\EZRI.EZBControl named 'Script Manager' does not exist. Can not send command 'ScriptStopAll'. 24.03.2017 10:07:01C:\Users\Stiko\Documents\EZ-Builder\My Projects\EZRI.EZBControl named 'Robot Dancing Music' does not exist. Can not send command 'stop'. 24.03.2017 10:07:01C:\Users\Stiko\Documents\EZ-Builder\My Projects\EZRI.EZBControl named 'Rear Arm' does not exist. Can not send command 'AutoPositionStop'. 24.03.2017 10:07:01C:\Users\Stiko\Documents\EZ-Builder\My Projects\EZRI.EZBControl named 'Front Arm' does not exist. Can not send command 'AutoPositionStop'. 24.03.2017 10:07:07C:\Users\Stiko\Documents\EZ-Builder\My Projects\EZRI.EZBControl named 'Script Manager' does not exist. Can not send command 'ScriptStopAll'. 24.03.2017 10:07:07C:\Users\Stiko\Documents\EZ-Builder\My Projects\EZRI.EZBControl named 'Robot Dancing Music' does not exist. Can not send command 'stop'. 24.03.2017 10:07:07C:\Users\Stiko\Documents\EZ-Builder\My Projects\EZRI.EZBControl named 'Rear Arm' does not exist. Can not send command 'AutoPositionStop'. 24.03.2017 10:07:07C:\Users\Stiko\Documents\EZ-Builder\My Projects\EZRI.EZBControl named 'Front Arm' does not exist. Can not send command 'AutoPositionStop'. 24.03.2017 10:09:22C:\Users\Stiko\Documents\EZ-Builder\My Projects\EZRI.EZBControl named 'Script Manager' does not exist. Can not send command 'ScriptStopAll'. 24.03.2017 10:09:22C:\Users\Stiko\Documents\EZ-Builder\My Projects\EZRI.EZBControl named 'Robot Dancing Music' does not exist. Can not send command 'stop'. 24.03.2017 10:09:22C:\Users\Stiko\Documents\EZ-Builder\My Projects\EZRI.EZBControl named 'Rear Arm' does not exist. Can not send command 'AutoPositionStop'. 24.03.2017 10:09:22C:\Users\Stiko\Documents\EZ-Builder\My Projects\EZRI.EZBControl named 'Front Arm' does not exist. Can not send command 'AutoPositionStop'. 24.03.2017 10:10:22C:\Users\Stiko\Documents\EZ-Builder\My Projects\EZRI.EZBControl named 'Script Manager' does not exist. Can not send command 'ScriptStopAll'. 24.03.2017 10:10:22C:\Users\Stiko\Documents\EZ-Builder\My Projects\EZRI.EZBControl named 'Robot Dancing Music' does not exist. Can not send command 'stop'. 24.03.2017 10:10:22C:\Users\Stiko\Documents\EZ-Builder\My Projects\EZRI.EZBControl named 'Rear Arm' does not exist. Can not send command 'AutoPositionStop'. 24.03.2017 10:10:22C:\Users\Stiko\Documents\EZ-Builder\My Projects\EZRI.EZBControl named 'Front Arm' does not exist. Can not send command 'AutoPositionStop'. 24.03.2017 10:10:33C:\Users\Stiko\Documents\EZ-Builder\My Projects\EZRI.EZBControl named 'Script Manager' does not exist. Can not send command 'ScriptStopAll'. 24.03.2017 10:10:33C:\Users\Stiko\Documents\EZ-Builder\My Projects\EZRI.EZBControl named 'Robot Dancing Music' does not exist. Can not send command 'stop'. 24.03.2017 10:10:33C:\Users\Stiko\Documents\EZ-Builder\My Projects\EZRI.EZBControl named 'Rear Arm' does not exist. Can not send command 'AutoPositionStop'. 24.03.2017 10:10:33C:\Users\Stiko\Documents\EZ-Builder\My Projects\EZRI.EZBControl named 'Front Arm' does not exist. Can not send command 'AutoPositionStop'. 24.03.2017 10:10:46C:\Users\Stiko\Documents\EZ-Builder\My Projects\EZRI.EZBControl named 'Script Manager' does not exist. Can not send command 'ScriptStopAll'. 24.03.2017 10:10:46C:\Users\Stiko\Documents\EZ-Builder\My Projects\EZRI.EZBControl named 'Robot Dancing Music' does not exist. Can not send command 'stop'. 24.03.2017 10:10:46C:\Users\Stiko\Documents\EZ-Builder\My Projects\EZRI.EZBControl named 'Rear Arm' does not exist. Can not send command 'AutoPositionStop'. 24.03.2017 10:10:46C:\Users\Stiko\Documents\EZ-Builder\My Projects\EZRI.EZBControl named 'Front Arm' does not exist. Can not send command 'AutoPositionStop'. 24.03.2017 10:12:06C:\Users\Stiko\Documents\EZ-Builder\My Projects\EZRI.EZBControl named 'Script Manager' does not exist. Can not send command 'ScriptStopAll'. 24.03.2017 10:12:06C:\Users\Stiko\Documents\EZ-Builder\My Projects\EZRI.EZBControl named 'Robot Dancing Music' does not exist. Can not send command 'stop'. 24.03.2017 10:12:06C:\Users\Stiko\Documents\EZ-Builder\My Projects\EZRI.EZBControl named 'Rear Arm' does not exist. Can not send command 'AutoPositionStop'. 24.03.2017 10:12:06C:\Users\Stiko\Documents\EZ-Builder\My Projects\EZRI.EZBControl named 'Front Arm' does not exist. Can not send command 'AutoPositionStop'. 24.03.2017 10:12:57C:\Users\Stiko\Documents\EZ-Builder\My Projects\EZRI.EZBControl named 'Script Manager' does not exist. Can not send command 'ScriptStopAll'. 24.03.2017 10:12:57C:\Users\Stiko\Documents\EZ-Builder\My Projects\EZRI.EZBControl named 'Robot Dancing Music' does not exist. Can not send command 'stop'. 24.03.2017 10:12:57C:\Users\Stiko\Documents\EZ-Builder\My Projects\EZRI.EZBControl named 'Rear Arm' does not exist. Can not send command 'AutoPositionStop'. 24.03.2017 10:12:57C:\Users\Stiko\Documents\EZ-Builder\My Projects\EZRI.EZBControl named 'Front Arm' does not exist. Can not send command 'AutoPositionStop'. 24.03.2017 10:15:55C:\Users\Stiko\Documents\EZ-Builder\My Projects\EZRI.EZBControl named 'Script Manager' does not exist. Can not send command 'ScriptStopAll'. 24.03.2017 10:15:55C:\Users\Stiko\Documents\EZ-Builder\My Projects\EZRI.EZBControl named 'Robot Dancing Music' does not exist. Can not send command 'stop'. 24.03.2017 10:15:55C:\Users\Stiko\Documents\EZ-Builder\My Projects\EZRI.EZBControl named 'Rear Arm' does not exist. Can not send command 'AutoPositionStop'. 24.03.2017 10:15:55C:\Users\Stiko\Documents\EZ-Builder\My Projects\EZRI.EZBControl named 'Front Arm' does not exist. Can not send command 'AutoPositionStop'. 24.03.2017 10:16:48C:\Users\Stiko\Documents\EZ-Builder\My Projects\EZRI.EZBControl named 'Script Manager' does not exist. Can not send command 'ScriptStopAll'. 24.03.2017 10:16:48C:\Users\Stiko\Documents\EZ-Builder\My Projects\EZRI.EZBControl named 'Robot Dancing Music' does not exist. Can not send command 'stop'. 24.03.2017 10:16:48C:\Users\Stiko\Documents\EZ-Builder\My Projects\EZRI.EZBControl named 'Rear Arm' does not exist. Can not send command 'AutoPositionStop'. 24.03.2017 10:16:48C:\Users\Stiko\Documents\EZ-Builder\My Projects\EZRI.EZBControl named 'Front Arm' does not exist. Can not send command 'AutoPositionStop'. 24.03.2017 10:17:13C:\Users\Stiko\Documents\EZ-Builder\My Projects\EZRI.EZBControl named 'Script Manager' does not exist. Can not send command 'ScriptStopAll'. 24.03.2017 10:17:13C:\Users\Stiko\Documents\EZ-Builder\My Projects\EZRI.EZBControl named 'Robot Dancing Music' does not exist. Can not send command 'stop'. 24.03.2017 10:17:13C:\Users\Stiko\Documents\EZ-Builder\My Projects\EZRI.EZBControl named 'Rear Arm' does not exist. Can not send command 'AutoPositionStop'. 24.03.2017 10:17:13C:\Users\Stiko\Documents\EZ-Builder\My Projects\EZRI.EZBControl named 'Front Arm' does not exist. Can not send command 'AutoPositionStop'. 24.03.2017 10:17:33C:\Users\Stiko\Documents\EZ-Builder\My Projects\EZRI.EZBControl named 'Script Manager' does not exist. Can not send command 'ScriptStopAll'. 24.03.2017 10:17:33C:\Users\Stiko\Documents\EZ-Builder\My Projects\EZRI.EZBControl named 'Robot Dancing Music' does not exist. Can not send command 'stop'. 24.03.2017 10:17:33C:\Users\Stiko\Documents\EZ-Builder\My Projects\EZRI.EZBControl named 'Rear Arm' does not exist. Can not send command 'AutoPositionStop'. 24.03.2017 10:17:33C:\Users\Stiko\Documents\EZ-Builder\My Projects\EZRI.EZBControl named 'Front Arm' does not exist. Can not send command 'AutoPositionStop'. 24.03.2017 10:18:28C:\Users\Stiko\Documents\EZ-Builder\My Projects\EZRI.EZBControl named 'Script Manager' does not exist. Can not send command 'ScriptStopAll'. 24.03.2017 10:18:28C:\Users\Stiko\Documents\EZ-Builder\My Projects\EZRI.EZBControl named 'Robot Dancing Music' does not exist. Can not send command 'stop'. 24.03.2017 10:18:28C:\Users\Stiko\Documents\EZ-Builder\My Projects\EZRI.EZBControl named 'Rear Arm' does not exist. Can not send command 'AutoPositionStop'. 24.03.2017 10:18:28C:\Users\Stiko\Documents\EZ-Builder\My Projects\EZRI.EZBControl named 'Front Arm' does not exist. Can not send command 'AutoPositionStop'. 24.03.2017 10:31:11C:\Users\Stiko\Documents\EZ-Builder\My Projects\EZRI.EZBControl named 'Script Manager' does not exist. Can not send command 'ScriptStopAll'. 24.03.2017 10:31:11C:\Users\Stiko\Documents\EZ-Builder\My Projects\EZRI.EZBControl named 'Robot Dancing Music' does not exist. Can not send command 'stop'. 24.03.2017 10:31:11C:\Users\Stiko\Documents\EZ-Builder\My Projects\EZRI.EZBControl named 'Rear Arm' does not exist. Can not send command 'AutoPositionStop'. 24.03.2017 10:31:11C:\Users\Stiko\Documents\EZ-Builder\My Projects\EZRI.EZBControl named 'Front Arm' does not exist. Can not send command 'AutoPositionStop'. 24.03.2017 10:36:12C:\Users\Stiko\Documents\EZ-Builder\My Projects\EZRI.EZBControl named 'Script Manager' does not exist. Can not send command 'ScriptStopAll'. 24.03.2017 10:36:12C:\Users\Stiko\Documents\EZ-Builder\My Projects\EZRI.EZBControl named 'Robot Dancing Music' does not exist. Can not send command 'stop'. 24.03.2017 10:36:12C:\Users\Stiko\Documents\EZ-Builder\My Projects\EZRI.EZBControl named 'Rear Arm' does not exist. Can not send command 'AutoPositionStop'. 24.03.2017 10:36:12C:\Users\Stiko\Documents\EZ-Builder\My Projects\EZRI.EZBControl named 'Front Arm' does not exist. Can not send command 'AutoPositionStop'. 24.03.2017 10:36:57C:\Users\Stiko\Documents\EZ-Builder\My Projects\EZRI.EZBConnection Failed: System.Exception: Already connected. bei EZ_B.EZB.Connect(String hostname, Int32 baudRate) 24.03.2017 21:22:30C:\Users\Stiko\Documents\EZ-Builder\My Projects\EZRI.EZBControl named 'Script Manager' does not exist. Can not send command 'ScriptStopAll'. 24.03.2017 21:22:30C:\Users\Stiko\Documents\EZ-Builder\My Projects\EZRI.EZBControl named 'Robot Dancing Music' does not exist. Can not send command 'stop'. 24.03.2017 21:22:30C:\Users\Stiko\Documents\EZ-Builder\My Projects\EZRI.EZBControl named 'Rear Arm' does not exist. Can not send command 'AutoPositionStop'. 24.03.2017 21:22:30C:\Users\Stiko\Documents\EZ-Builder\My Projects\EZRI.EZBControl named 'Front Arm' does not exist. Can not send command 'AutoPositionStop'. 24.03.2017 21:24:27C:\Users\Stiko\Documents\EZ-Builder\My Projects\EZRI.EZBControl named 'Script Manager' does not exist. Can not send command 'ScriptStopAll'. 24.03.2017 21:24:27C:\Users\Stiko\Documents\EZ-Builder\My Projects\EZRI.EZBControl named 'Robot Dancing Music' does not exist. Can not send command 'stop'. 24.03.2017 21:24:27C:\Users\Stiko\Documents\EZ-Builder\My Projects\EZRI.EZBControl named 'Rear Arm' does not exist. Can not send command 'AutoPositionStop'. 24.03.2017 21:24:27C:\Users\Stiko\Documents\EZ-Builder\My Projects\EZRI.EZBControl named 'Front Arm' does not exist. Can not send command 'AutoPositionStop'. 24.03.2017 21:27:18C:\Users\Stiko\Documents\EZ-Builder\My Projects\EZRI.EZBComm Err: System.IO.IOException: Von der bertragungsverbindung knnen keine Daten gelesen werden: Ein Verbindungsversuch ist fehlgeschlagen, da die Gegenstelle nach einer bestimmten Zeitspanne nicht richtig reagiert hat, oder die hergestellte Verbindung war fehlerhaft, da der verbundene Host nicht reagiert hat. ---> System.Net.Sockets.SocketException: Ein Verbindungsversuch ist fehlgeschlagen, da die Gegenstelle nach einer bestimmten Zeitspanne nicht richtig reagiert hat, oder die hergestellte Verbindung war fehlerhaft, da der verbundene Host nicht reagiert hat bei System.Net.Sockets.Socket.Receive(Byte[] buffer, Int32 offset, Int32 size, SocketFlags socketFlags) bei System.Net.Sockets.NetworkStream.Read(Byte[] buffer, Int32 offset, Int32 size) --- Ende der internen Ausnahmestapelberwachung --- bei System.Net.Sockets.NetworkStream.Read(Byte[] buffer, Int32 offset, Int32 size) bei EZ_B.EZB.DcGTgCUQXR(Int32 , Byte[] cmdData) 24.03.2017 21:27:18C:\Users\Stiko\Documents\EZ-Builder\My Projects\EZRI.EZBBbytesToExpect: 2 24.03.2017 21:27:18C:\Users\Stiko\Documents\EZ-Builder\My Projects\EZRI.EZB Received: 0 0 24.03.2017 21:27:18C:\Users\Stiko\Documents\EZ-Builder\My Projects\EZRI.EZBDisconnected 24.03.2017 22:32:35C:\Users\Stiko\Documents\EZ-Builder\My Projects\EZRI.EZBControl named 'Script Manager' does not exist. Can not send command 'ScriptStopAll'. 24.03.2017 22:32:35C:\Users\Stiko\Documents\EZ-Builder\My Projects\EZRI.EZBControl named 'Robot Dancing Music' does not exist. Can not send command 'stop'. 24.03.2017 22:32:35C:\Users\Stiko\Documents\EZ-Builder\My Projects\EZRI.EZBControl named 'Rear Arm' does not exist. Can not send command 'AutoPositionStop'. 24.03.2017 22:32:35C:\Users\Stiko\Documents\EZ-Builder\My Projects\EZRI.EZBControl named 'Front Arm' does not exist. Can not send command 'AutoPositionStop'. 24.03.2017 22:32:52C:\Users\Stiko\Documents\EZ-Builder\My Projects\EZRI.EZBConnection Failed: System.Exception: Already connected. bei EZ_B.EZB.Connect(String hostname, Int32 baudRate) 24.03.2017 22:32:52C:\Users\Stiko\Documents\EZ-Builder\My Projects\EZRI.EZBDisconnected 24.03.2017 22:33:05C:\Users\Stiko\Documents\EZ-Builder\My Projects\EZRI.EZBControl named 'Script Manager' does not exist. Can not send command 'ScriptStopAll'. 24.03.2017 22:33:05C:\Users\Stiko\Documents\EZ-Builder\My Projects\EZRI.EZBControl named 'Robot Dancing Music' does not exist. Can not send command 'stop'. 24.03.2017 22:33:05C:\Users\Stiko\Documents\EZ-Builder\My Projects\EZRI.EZBControl named 'Rear Arm' does not exist. Can not send command 'AutoPositionStop'. 24.03.2017 22:33:05C:\Users\Stiko\Documents\EZ-Builder\My Projects\EZRI.EZBControl named 'Front Arm' does not exist. Can not send command 'AutoPositionStop'. 24.03.2017 22:40:31C:\Users\Stiko\Documents\EZ-Builder\My Projects\EZRI.EZBControl named 'Script Manager' does not exist. Can not send command 'ScriptStopAll'. 24.03.2017 22:40:31C:\Users\Stiko\Documents\EZ-Builder\My Projects\EZRI.EZBControl named 'Robot Dancing Music' does not exist. Can not send command 'stop'. 24.03.2017 22:40:31C:\Users\Stiko\Documents\EZ-Builder\My Projects\EZRI.EZBControl named 'Rear Arm' does not exist. Can not send command 'AutoPositionStop'. 24.03.2017 22:40:31C:\Users\Stiko\Documents\EZ-Builder\My Projects\EZRI.EZBControl named 'Front Arm' does not exist. Can not send command 'AutoPositionStop'. 24.03.2017 22:43:34C:\Users\Stiko\Documents\EZ-Builder\My Projects\EZRI.EZBControl named 'Script Manager' does not exist. Can not send command 'ScriptStopAll'. 24.03.2017 22:43:34C:\Users\Stiko\Documents\EZ-Builder\My Projects\EZRI.EZBControl named 'Robot Dancing Music' does not exist. Can not send command 'stop'. 24.03.2017 22:44:30C:\Users\Stiko\Documents\EZ-Builder\My Projects\EZRI.EZBControl named 'Script Manager' does not exist. Can not send command 'ScriptStopAll'. 24.03.2017 22:44:30C:\Users\Stiko\Documents\EZ-Builder\My Projects\EZRI.EZBControl named 'Robot Dancing Music' does not exist. Can not send command 'stop'. 24.03.2017 22:46:13C:\Users\Stiko\Documents\EZ-Builder\My Projects\EZRI.EZBCamera Initialized: EZB://192.168.178.39 @ 640x480 24.03.2017 22:46:57C:\Users\Stiko\Documents\EZ-Builder\My Projects\EZRI.EZBControl named 'Script Manager' does not exist. Can not send command 'ScriptStopAll'. 24.03.2017 22:46:57C:\Users\Stiko\Documents\EZ-Builder\My Projects\EZRI.EZBControl named 'Robot Dancing Music' does not exist. Can not send command 'stop'. 24.03.2017 22:46:57C:\Users\Stiko\Documents\EZ-Builder\My Projects\EZRI.EZBControl named 'Rear Arm' does not exist. Can not send command 'AutoPositionStop'. 24.03.2017 22:46:57C:\Users\Stiko\Documents\EZ-Builder\My Projects\EZRI.EZBControl named 'Front Arm' does not exist. Can not send command 'AutoPositionStop'. 24.03.2017 22:50:02C:\Users\Stiko\Documents\EZ-Builder\My Projects\EZRI.EZBControl named 'Script Manager' does not exist. Can not send command 'ScriptStopAll'. 24.03.2017 22:50:02C:\Users\Stiko\Documents\EZ-Builder\My Projects\EZRI.EZBControl named 'Robot Dancing Music' does not exist. Can not send command 'stop'. 24.03.2017 22:52:35C:\Users\Stiko\Documents\EZ-Builder\My Projects\EZRI.EZBControl named 'Script Manager' does not exist. Can not send command 'ScriptStopAll'. 24.03.2017 22:52:35C:\Users\Stiko\Documents\EZ-Builder\My Projects\EZRI.EZBControl named 'Robot Dancing Music' does not exist. Can not send command 'stop'. 24.03.2017 23:00:25C:\Users\Stiko\Documents\EZ-Builder\My Projects\EZRI.EZBControl named 'Script Manager' does not exist. Can not send command 'ScriptStopAll'. 24.03.2017 23:00:25C:\Users\Stiko\Documents\EZ-Builder\My Projects\EZRI.EZBControl named 'Robot Dancing Music' does not exist. Can not send command 'stop'. 24.03.2017 23:00:25C:\Users\Stiko\Documents\EZ-Builder\My Projects\EZRI.EZBControl named 'Rear Arm' does not exist. Can not send command 'AutoPositionStop'. 24.03.2017 23:00:25C:\Users\Stiko\Documents\EZ-Builder\My Projects\EZRI.EZBControl named 'Front Arm' does not exist. Can not send command 'AutoPositionStop'. 24.03.2017 23:00:35C:\Users\Stiko\Documents\EZ-Builder\My Projects\EZRI.EZBControl named 'Script Manager' does not exist. Can not send command 'ScriptStopAll'. 24.03.2017 23:00:35C:\Users\Stiko\Documents\EZ-Builder\My Projects\EZRI.EZBControl named 'Robot Dancing Music' does not exist. Can not send command 'stop'. 24.03.2017 23:00:59C:\Users\Stiko\Documents\EZ-Builder\My Projects\EZRI.EZBControl named 'Script Manager' does not exist. Can not send command 'ScriptStopAll'. 24.03.2017 23:00:59C:\Users\Stiko\Documents\EZ-Builder\My Projects\EZRI.EZBControl named 'Robot Dancing Music' does not exist. Can not send command 'stop'. 24.03.2017 23:01:22C:\Users\Stiko\Documents\EZ-Builder\My Projects\EZRI.EZBSpeech Synthesis Error (SayEZB): System.InvalidOperationException: Die Ausgabe des Synthesizers kann whrend des Sprechens nicht gendert werden. bei System.Speech.Internal.Synthesis.VoiceSynthesis.SetOutput(Stream stream, SpeechAudioFormatInfo formatInfo, Boolean headerInfo) bei System.Speech.Synthesis.SpeechSynthesizer.SetOutputToNull() bei System.Speech.Synthesis.SpeechSynthesizer.SetOutputStream(Stream stream, SpeechAudioFormatInfo formatInfo, Boolean headerInfo, Boolean closeStreamOnExit) bei System.Speech.Synthesis.SpeechSynthesizer.SetOutputToAudioStream(Stream audioDestination, SpeechAudioFormatInfo formatInfo) bei EZ_B.SpeechSynth.SayToStream(String msg) bei EZ_Builder.UCForms.FormSpeechSynthesis.WY9tZY539q1(Object , EventArgs ) 24.03.2017 23:07:50C:\Users\Stiko\Documents\EZ-Builder\My Projects\EZRI.EZBControl named 'Script Manager' does not exist. Can not send command 'ScriptStopAll'. 24.03.2017 23:07:50C:\Users\Stiko\Documents\EZ-Builder\My Projects\EZRI.EZBControl named 'Robot Dancing Music' does not exist. Can not send command 'stop'. 24.03.2017 23:09:28C:\Users\Stiko\Documents\EZ-Builder\My Projects\EZRI.EZBControl named 'Script Manager' does not exist. Can not send command 'ScriptStopAll'. 24.03.2017 23:09:28C:\Users\Stiko\Documents\EZ-Builder\My Projects\EZRI.EZBControl named 'Robot Dancing Music' does not exist. Can not send command 'stop'. 24.03.2017 23:09:43C:\Users\Stiko\Documents\EZ-Builder\My Projects\EZRI.EZBControl named 'Script Manager' does not exist. Can not send command 'ScriptStopAll'. 24.03.2017 23:09:43C:\Users\Stiko\Documents\EZ-Builder\My Projects\EZRI.EZBControl named 'Robot Dancing Music' does not exist. Can not send command 'stop'. 24.03.2017 23:10:55C:\Users\Stiko\Documents\EZ-Builder\My Projects\EZRI.EZBControl named 'Script Manager' does not exist. Can not send command 'ScriptStopAll'. 24.03.2017 23:10:55C:\Users\Stiko\Documents\EZ-Builder\My Projects\EZRI.EZBControl named 'Robot Dancing Music' does not exist. Can not send command 'stop'. 24.03.2017 23:11:38C:\Users\Stiko\Documents\EZ-Builder\My Projects\EZRI.EZBControl named 'Script Manager' does not exist. Can not send command 'ScriptStopAll'. 24.03.2017 23:11:38C:\Users\Stiko\Documents\EZ-Builder\My Projects\EZRI.EZBControl named 'Robot Dancing Music' does not exist. Can not send command 'stop'. 24.03.2017 23:11:39C:\Users\Stiko\Documents\EZ-Builder\My Projects\EZRI.EZBConnection Failed: System.Exception: Already connected. bei EZ_B.EZB.Connect(String hostname, Int32 baudRate) 24.03.2017 23:11:39C:\Users\Stiko\Documents\EZ-Builder\My Projects\EZRI.EZBDisconnected 24.03.2017 23:11:39C:\Users\Stiko\Documents\EZ-Builder\My Projects\EZRI.EZBComm Err: System.IO.IOException: Von der bertragungsverbindung knnen keine Daten gelesen werden: Ein Blockierungsvorgang wurde durch einen Aufruf von WSACancelBlockingCall unterbrochen. ---> System.Net.Sockets.SocketException: Ein Blockierungsvorgang wurde durch einen Aufruf von WSACancelBlockingCall unterbrochen bei System.Net.Sockets.Socket.Receive(Byte[] buffer, Int32 offset, Int32 size, SocketFlags socketFlags) bei System.Net.Sockets.NetworkStream.Read(Byte[] buffer, Int32 offset, Int32 size) --- Ende der internen Ausnahmestapelberwachung --- bei System.Net.Sockets.NetworkStream.Read(Byte[] buffer, Int32 offset, Int32 size) bei EZ_B.EZB.DcGTgCUQXR(Int32 , Byte[] cmdData) 24.03.2017 23:11:39C:\Users\Stiko\Documents\EZ-Builder\My Projects\EZRI.EZBBbytesToExpect: 2 24.03.2017 23:11:39C:\Users\Stiko\Documents\EZ-Builder\My Projects\EZRI.EZB Received: 0 0 24.03.2017 23:11:39C:\Users\Stiko\Documents\EZ-Builder\My Projects\EZRI.EZBDisconnected 24.03.2017 23:11:58C:\Users\Stiko\Documents\EZ-Builder\My Projects\EZRI.EZBConnected 24.03.2017 23:13:47C:\Users\Stiko\Documents\EZ-Builder\My Projects\EZRI.EZBControl named 'Script Manager' does not exist. Can not send command 'ScriptStopAll'. 24.03.2017 23:13:47C:\Users\Stiko\Documents\EZ-Builder\My Projects\EZRI.EZBControl named 'Robot Dancing Music' does not exist. Can not send command 'stop'. 24.03.2017 23:16:46C:\Users\Stiko\Documents\EZ-Builder\My Projects\EZRI.EZBControl named 'Script Manager' does not exist. Can not send command 'ScriptStopAll'. 24.03.2017 23:16:46C:\Users\Stiko\Documents\EZ-Builder\My Projects\EZRI.EZBControl named 'Robot Dancing Music' does not exist. Can not send command 'stop'. 24.03.2017 23:21:18C:\Users\Stiko\Documents\EZ-Builder\My Projects\EZRI.EZBControl named 'Script Manager' does not exist. Can not send command 'ScriptStopAll'. 24.03.2017 23:21:18C:\Users\Stiko\Documents\EZ-Builder\My Projects\EZRI.EZBControl named 'Robot Dancing Music' does not exist. Can not send command 'stop'. 24.03.2017 23:22:34C:\Users\Stiko\Documents\EZ-Builder\My Projects\EZRI.EZBControl named 'Script Manager' does not exist. Can not send command 'ScriptStopAll'. 24.03.2017 23:22:34C:\Users\Stiko\Documents\EZ-Builder\My Projects\EZRI.EZBControl named 'Robot Dancing Music' does not exist. Can not send command 'stop'. 24.03.2017 23:22:34C:\Users\Stiko\Documents\EZ-Builder\My Projects\EZRI.EZBControl named 'Rear Arm' does not exist. Can not send command 'AutoPositionStop'. 24.03.2017 23:22:34C:\Users\Stiko\Documents\EZ-Builder\My Projects\EZRI.EZBControl named 'Front Arm' does not exist. Can not send command 'AutoPositionStop'. 24.03.2017 23:22:52C:\Users\Stiko\Documents\EZ-Builder\My Projects\EZRI.EZBControl named 'Script Manager' does not exist. Can not send command 'ScriptStopAll'. 24.03.2017 23:22:52C:\Users\Stiko\Documents\EZ-Builder\My Projects\EZRI.EZBControl named 'Robot Dancing Music' does not exist. Can not send command 'stop'. 24.03.2017 23:23:01C:\Users\Stiko\Documents\EZ-Builder\My Projects\EZRI.EZBControl named 'Script Manager' does not exist. Can not send command 'ScriptStopAll'. 24.03.2017 23:23:01C:\Users\Stiko\Documents\EZ-Builder\My Projects\EZRI.EZBControl named 'Robot Dancing Music' does not exist. Can not send command 'stop'. 24.03.2017 23:29:46C:\Users\Stiko\Documents\EZ-Builder\My Projects\EZRI.EZBControl named 'Script Manager' does not exist. Can not send command 'ScriptStopAll'. 24.03.2017 23:29:46C:\Users\Stiko\Documents\EZ-Builder\My Projects\EZRI.EZBControl named 'Robot Dancing Music' does not exist. Can not send command 'stop'. 24.03.2017 23:33:38C:\Users\Stiko\Documents\EZ-Builder\My Projects\EZRI.EZBControl named 'Script Manager' does not exist. Can not send command 'ScriptStopAll'. 24.03.2017 23:33:38C:\Users\Stiko\Documents\EZ-Builder\My Projects\EZRI.EZBControl named 'Robot Dancing Music' does not exist. Can not send command 'stop'. 24.03.2017 23:35:51C:\Users\Stiko\Documents\EZ-Builder\My Projects\EZRI.EZBControl named 'Script Manager' does not exist. Can not send command 'ScriptStopAll'. 24.03.2017 23:35:51C:\Users\Stiko\Documents\EZ-Builder\My Projects\EZRI.EZBControl named 'Robot Dancing Music' does not exist. Can not send command 'stop'. 24.03.2017 23:35:57C:\Users\Stiko\Documents\EZ-Builder\My Projects\EZRI.EZBControl named 'Script Manager' does not exist. Can not send command 'ScriptStopAll'. 24.03.2017 23:35:57C:\Users\Stiko\Documents\EZ-Builder\My Projects\EZRI.EZBControl named 'Robot Dancing Music' does not exist. Can not send command 'stop'. 24.03.2017 23:44:04C:\Users\Stiko\Documents\EZ-Builder\My Projects\EZRI.EZBControl named 'Script Manager' does not exist. Can not send command 'ScriptStopAll'. 24.03.2017 23:44:04C:\Users\Stiko\Documents\EZ-Builder\My Projects\EZRI.EZBControl named 'Robot Dancing Music' does not exist. Can not send command 'stop'. 24.03.2017 23:44:35C:\Users\Stiko\Documents\EZ-Builder\My Projects\EZRI.EZBControl named 'Script Manager' does not exist. Can not send command 'ScriptStopAll'. 24.03.2017 23:44:35C:\Users\Stiko\Documents\EZ-Builder\My Projects\EZRI.EZBControl named 'Robot Dancing Music' does not exist. Can not send command 'stop'. 25.03.2017 00:06:04C:\Users\Stiko\Documents\EZ-Builder\My Projects\EZRI.EZBComm Err: System.IO.IOException: Von der bertragungsverbindung knnen keine Daten gelesen werden: Ein Verbindungsversuch ist fehlgeschlagen, da die Gegenstelle nach einer bestimmten Zeitspanne nicht richtig reagiert hat, oder die hergestellte Verbindung war fehlerhaft, da der verbundene Host nicht reagiert hat. ---> System.Net.Sockets.SocketException: Ein Verbindungsversuch ist fehlgeschlagen, da die Gegenstelle nach einer bestimmten Zeitspanne nicht richtig reagiert hat, oder die hergestellte Verbindung war fehlerhaft, da der verbundene Host nicht reagiert hat bei System.Net.Sockets.Socket.Receive(Byte[] buffer, Int32 offset, Int32 size, SocketFlags socketFlags) bei System.Net.Sockets.NetworkStream.Read(Byte[] buffer, Int32 offset, Int32 size) --- Ende der internen Ausnahmestapelberwachung --- bei System.Net.Sockets.NetworkStream.Read(Byte[] buffer, Int32 offset, Int32 size) bei EZ_B.EZB.DcGTgCUQXR(Int32 , Byte[] cmdData) 25.03.2017 00:06:04C:\Users\Stiko\Documents\EZ-Builder\My Projects\EZRI.EZBBbytesToExpect: 2 25.03.2017 00:06:04C:\Users\Stiko\Documents\EZ-Builder\My Projects\EZRI.EZB? Received: 0 0 25.03.2017 00:06:04C:\Users\Stiko\Documents\EZ-Builder\My Projects\EZRI.EZBEZ-B v4 Camera Error: System.IO.IOException: Von der bertragungsverbindung knnen keine Daten gelesen werden: Ein Verbindungsversuch ist fehlgeschlagen, da die Gegenstelle nach einer bestimmten Zeitspanne nicht richtig reagiert hat, oder die hergestellte Verbindung war fehlerhaft, da der verbundene Host nicht reagiert hat. ---> System.Net.Sockets.SocketException: Ein Verbindungsversuch ist fehlgeschlagen, da die Gegenstelle nach einer bestimmten Zeitspanne nicht richtig reagiert hat, oder die hergestellte Verbindung war fehlerhaft, da der verbundene Host nicht reagiert hat bei System.Net.Sockets.Socket.Receive(Byte[] buffer, Int32 offset, Int32 size, SocketFlags socketFlags) bei System.Net.Sockets.NetworkStream.Read(Byte[] buffer, Int32 offset, Int32 size) --- Ende der internen Ausnahmestapelberwachung --- bei System.Net.Sockets.NetworkStream.Read(Byte[] buffer, Int32 offset, Int32 size) bei EZ_B.EZBv4Video.pZy8bfPYaa(Int32 , Object ) 25.03.2017 00:07:43C:\Users\Stiko\Documents\EZ-Builder\My Projects\EZRI.EZBControl named 'Script Manager' does not exist. Can not send command 'ScriptStopAll'. 25.03.2017 00:07:43C:\Users\Stiko\Documents\EZ-Builder\My Projects\EZRI.EZBControl named 'Robot Dancing Music' does not exist. Can not send command 'stop'. 25.03.2017 00:07:52C:\Users\Stiko\Documents\EZ-Builder\My Projects\EZRI.EZBControl named 'Script Manager' does not exist. Can not send command 'ScriptStopAll'. 25.03.2017 00:07:52C:\Users\Stiko\Documents\EZ-Builder\My Projects\EZRI.EZBControl named 'Robot Dancing Music' does not exist. Can not send command 'stop'. 25.03.2017 00:09:30C:\Users\Stiko\Documents\EZ-Builder\My Projects\EZRI.EZBControl named 'Script Manager' does not exist. Can not send command 'ScriptStopAll'. 25.03.2017 00:09:30C:\Users\Stiko\Documents\EZ-Builder\My Projects\EZRI.EZBControl named 'Robot Dancing Music' does not exist. Can not send command 'stop'. 25.03.2017 00:09:50C:\Users\Stiko\Documents\EZ-Builder\My Projects\EZRI.EZBControl named 'Script Manager' does not exist. Can not send command 'ScriptStopAll'. 25.03.2017 00:09:50C:\Users\Stiko\Documents\EZ-Builder\My Projects\EZRI.EZBControl named 'Robot Dancing Music' does not exist. Can not send command 'stop'. 25.03.2017 00:10:02C:\Users\Stiko\Documents\EZ-Builder\My Projects\EZRI.EZBCamera Initialized: EZB://192.168.178.39 @ 640x480 25.03.2017 00:12:48C:\Users\Stiko\Documents\EZ-Builder\My Projects\EZRI.EZBControl named 'Script Manager' does not exist. Can not send command 'ScriptStopAll'. 25.03.2017 00:12:48C:\Users\Stiko\Documents\EZ-Builder\My Projects\EZRI.EZBControl named 'Robot Dancing Music' does not exist. Can not send command 'stop'. 25.03.2017 00:30:53C:\Users\Stiko\Documents\EZ-Builder\My Projects\EZRI.EZBSaved C:\Users\Stiko\Documents\EZ-Builder\My Projects\EZRI.EZB 25.03.2017 00:36:07C:\Users\Stiko\Documents\EZ-Builder\My Projects\EZRI.EZBSaved C:\Users\Stiko\Documents\EZ-Builder\My Projects\EZRI.EZB 25.03.2017 00:54:48C:\Users\Stiko\Documents\EZ-Builder\My Projects\EZRI.EZBControl named 'Script Manager' does not exist. Can not send command 'ScriptStopAll'. 25.03.2017 00:54:48C:\Users\Stiko\Documents\EZ-Builder\My Projects\EZRI.EZBControl named 'Robot Dancing Music' does not exist. Can not send command 'stop'. 25.03.2017 00:55:13C:\Users\Stiko\Documents\EZ-Builder\My Projects\EZRI.EZBSaved C:\Users\Stiko\Documents\EZ-Builder\My Projects\EZRI.EZB 25.03.2017 00:56:30C:\Users\Stiko\Documents\EZ-Builder\My Projects\EZRI.EZBSaved C:\Users\Stiko\Documents\EZ-Builder\My Projects\EZRI.EZB 25.03.2017 00:56:34C:\Users\Stiko\Documents\EZ-Builder\My Projects\EZRI.EZBSaved C:\Users\Stiko\Documents\EZ-Builder\My Projects\EZRI.EZB 25.03.2017 00:56:34C:\Users\Stiko\Documents\EZ-Builder\My Projects\EZRI.EZBDisconnected 25.03.2017 00:56:34C:\Users\Stiko\Documents\EZ-Builder\My Projects\EZRI.EZBCamera Disabled 25.03.2017 00:56:35C:\Users\Stiko\Documents\EZ-Builder\My Projects\EZRI.EZBError Camera.SetCaptureImage: System.NullReferenceException: Der Objektverweis wurde nicht auf eine Objektinstanz festgelegt. bei AForge.Imaging.Drawing.Line(UnmanagedImage image, IntPoint point1, IntPoint point2, Color color) bei EZ_B.Camera.Pr7VaILumf(Object ) 25.03.2017 00:56:35C:\Users\Stiko\Documents\EZ-Builder\My Projects\EZRI.EZBTCP Server stopped 25.03.2017 00:56:35C:\Users\Stiko\Documents\EZ-Builder\My Projects\EZRI.EZBTCP Server stopped 25.03.2017 00:56:35C:\Users\Stiko\Documents\EZ-Builder\My Projects\EZRI.EZBTCP Server stopped 25.03.2017 00:56:35C:\Users\Stiko\Documents\EZ-Builder\My Projects\EZRI.EZBTCP Server stopped 25.03.2017 00:56:35C:\Users\Stiko\Documents\EZ-Builder\My Projects\EZRI.EZBTCP Server stopped 25.03.2017 00:56:35C:\Users\Stiko\Documents\EZ-Builder\My Projects\EZRI.EZBTCP Server stopped 25.03.2017 00:56:35C:\Users\Stiko\Documents\EZ-Builder\My Projects\EZRI.EZBTCP Server stopped 25.03.2017 00:56:35C:\Users\Stiko\Documents\EZ-Builder\My Projects\EZRI.EZBTCP Server stopped 25.03.2017 00:56:35C:\Users\Stiko\Documents\EZ-Builder\My Projects\EZRI.EZBTCP Server stopped 25.03.2017 00:56:35C:\Users\Stiko\Documents\EZ-Builder\My Projects\EZRI.EZBTCP Server stopped 25.03.2017 08:19:30C:\Users\Stiko\Documents\EZ-Builder\My Projects\EZRI.EZBControl named 'Script Manager' does not exist. Can not send command 'ScriptStopAll'. 25.03.2017 08:19:30C:\Users\Stiko\Documents\EZ-Builder\My Projects\EZRI.EZBControl named 'Robot Dancing Music' does not exist. Can not send command 'stop'. 25.03.2017 08:25:55C:\Users\Stiko\Documents\EZ-Builder\My Projects\EZRI.EZBControl named 'Script Manager' does not exist. Can not send command 'ScriptStopAll'. 25.03.2017 08:25:55C:\Users\Stiko\Documents\EZ-Builder\My Projects\EZRI.EZBControl named 'Robot Dancing Music' does not exist. Can not send command 'stop'. 25.03.2017 08:30:42C:\Users\Stiko\Documents\EZ-Builder\My Projects\EZRI.EZBControl named 'Script Manager' does not exist. Can not send command 'ScriptStopAll'. 25.03.2017 08:30:42C:\Users\Stiko\Documents\EZ-Builder\My Projects\EZRI.EZBControl named 'Robot Dancing Music' does not exist. Can not send command 'stop'. 25.03.2017 08:32:12C:\Users\Stiko\Documents\EZ-Builder\My Projects\EZRI.EZBControl named 'Script Manager' does not exist. Can not send command 'ScriptStopAll'. 25.03.2017 08:32:12C:\Users\Stiko\Documents\EZ-Builder\My Projects\EZRI.EZBControl named 'Robot Dancing Music' does not exist. Can not send command 'stop'. 25.03.2017 08:34:14C:\Users\Stiko\Documents\EZ-Builder\My Projects\EZRI.EZBControl named 'Script Manager' does not exist. Can not send command 'ScriptStopAll'. 25.03.2017 08:34:14C:\Users\Stiko\Documents\EZ-Builder\My Projects\EZRI.EZBControl named 'Robot Dancing Music' does not exist. Can not send command 'stop'. 25.03.2017 08:34:14C:\Users\Stiko\Documents\EZ-Builder\My Projects\EZRI.EZBControl named 'Rear Arm' does not exist. Can not send command 'AutoPositionStop'. 25.03.2017 08:34:14C:\Users\Stiko\Documents\EZ-Builder\My Projects\EZRI.EZBControl named 'Front Arm' does not exist. Can not send command 'AutoPositionStop'. 25.03.2017 08:35:09C:\Users\Stiko\Documents\EZ-Builder\My Projects\EZRI.EZBControl named 'Script Manager' does not exist. Can not send command 'ScriptStopAll'. 25.03.2017 08:35:09C:\Users\Stiko\Documents\EZ-Builder\My Projects\EZRI.EZBControl named 'Robot Dancing Music' does not exist. Can not send command 'stop'. 25.03.2017 08:35:14C:\Users\Stiko\Documents\EZ-Builder\My Projects\EZRI.EZBComm Err: System.IO.IOException: Von der bertragungsverbindung knnen keine Daten gelesen werden: Ein Verbindungsversuch ist fehlgeschlagen, da die Gegenstelle nach einer bestimmten Zeitspanne nicht richtig reagiert hat, oder die hergestellte Verbindung war fehlerhaft, da der verbundene Host nicht reagiert hat. ---> System.Net.Sockets.SocketException: Ein Verbindungsversuch ist fehlgeschlagen, da die Gegenstelle nach einer bestimmten Zeitspanne nicht richtig reagiert hat, oder die hergestellte Verbindung war fehlerhaft, da der verbundene Host nicht reagiert hat bei System.Net.Sockets.Socket.Receive(Byte[] buffer, Int32 offset, Int32 size, SocketFlags socketFlags) bei System.Net.Sockets.NetworkStream.Read(Byte[] buffer, Int32 offset, Int32 size) --- Ende der internen Ausnahmestapelberwachung --- bei System.Net.Sockets.NetworkStream.Read(Byte[] buffer, Int32 offset, Int32 size) bei EZ_B.EZB.DcGTgCUQXR(Int32 , Byte[] cmdData) 25.03.2017 08:35:14C:\Users\Stiko\Documents\EZ-Builder\My Projects\EZRI.EZBBbytesToExpect: 2 25.03.2017 08:35:14C:\Users\Stiko\Documents\EZ-Builder\My Projects\EZRI.EZB Received: 0 0 25.03.2017 08:35:14C:\Users\Stiko\Documents\EZ-Builder\My Projects\EZRI.EZBDisconnected 25.03.2017 08:35:22C:\Users\Stiko\Documents\EZ-Builder\My Projects\EZRI.EZBAttempting connection on 192.168.178.39 25.03.2017 08:35:27C:\Users\Stiko\Documents\EZ-Builder\My Projects\EZRI.EZBComm Err: System.IO.IOException: Von der bertragungsverbindung knnen keine Daten gelesen werden: Ein Verbindungsversuch ist fehlgeschlagen, da die Gegenstelle nach einer bestimmten Zeitspanne nicht richtig reagiert hat, oder die hergestellte Verbindung war fehlerhaft, da der verbundene Host nicht reagiert hat. ---> System.Net.Sockets.SocketException: Ein Verbindungsversuch ist fehlgeschlagen, da die Gegenstelle nach einer bestimmten Zeitspanne nicht richtig reagiert hat, oder die hergestellte Verbindung war fehlerhaft, da der verbundene Host nicht reagiert hat bei System.Net.Sockets.Socket.Receive(Byte[] buffer, Int32 offset, Int32 size, SocketFlags socketFlags) bei System.Net.Sockets.NetworkStream.Read(Byte[] buffer, Int32 offset, Int32 size) --- Ende der internen Ausnahmestapelberwachung --- bei System.Net.Sockets.NetworkStream.Read(Byte[] buffer, Int32 offset, Int32 size) bei EZ_B.EZB.DcGTgCUQXR(Int32 , Byte[] cmdData) 25.03.2017 08:35:27C:\Users\Stiko\Documents\EZ-Builder\My Projects\EZRI.EZBBbytesToExpect: 1 25.03.2017 08:35:27C:\Users\Stiko\Documents\EZ-Builder\My Projects\EZRI.EZBU Received: 0 25.03.2017 08:35:27C:\Users\Stiko\Documents\EZ-Builder\My Projects\EZRI.EZBDisconnected 25.03.2017 08:35:27C:\Users\Stiko\Documents\EZ-Builder\My Projects\EZRI.EZBConnection Failed: System.Exception: Controller Not Responding bei EZ_B.EZB.jkbTpgud3g() bei EZ_B.EZB.Connect(String hostname, Int32 baudRate) 25.03.2017 08:35:27C:\Users\Stiko\Documents\EZ-Builder\My Projects\EZRI.EZBDisconnected 25.03.2017 08:35:36C:\Users\Stiko\Documents\EZ-Builder\My Projects\EZRI.EZBEZ-B v4 Camera Error: System.IO.IOException: Von der bertragungsverbindung knnen keine Daten gelesen werden: Ein Verbindungsversuch ist fehlgeschlagen, da die Gegenstelle nach einer bestimmten Zeitspanne nicht richtig reagiert hat, oder die hergestellte Verbindung war fehlerhaft, da der verbundene Host nicht reagiert hat. ---> System.Net.Sockets.SocketException: Ein Verbindungsversuch ist fehlgeschlagen, da die Gegenstelle nach einer bestimmten Zeitspanne nicht richtig reagiert hat, oder die hergestellte Verbindung war fehlerhaft, da der verbundene Host nicht reagiert hat bei System.Net.Sockets.Socket.Receive(Byte[] buffer, Int32 offset, Int32 size, SocketFlags socketFlags) bei System.Net.Sockets.NetworkStream.Read(Byte[] buffer, Int32 offset, Int32 size) --- Ende der internen Ausnahmestapelberwachung --- bei System.Net.Sockets.NetworkStream.Read(Byte[] buffer, Int32 offset, Int32 size) bei EZ_B.EZBv4Video.pZy8bfPYaa(Int32 , Object ) 25.03.2017 08:36:58C:\Users\Stiko\Documents\EZ-Builder\My Projects\EZRI.EZBControl named 'Script Manager' does not exist. Can not send command 'ScriptStopAll'. 25.03.2017 08:36:58C:\Users\Stiko\Documents\EZ-Builder\My Projects\EZRI.EZBControl named 'Robot Dancing Music' does not exist. Can not send command 'stop'. 25.03.2017 08:40:08C:\Users\Stiko\Documents\EZ-Builder\My Projects\EZRI.EZBControl named 'Script Manager' does not exist. Can not send command 'ScriptStopAll'. 25.03.2017 08:40:08C:\Users\Stiko\Documents\EZ-Builder\My Projects\EZRI.EZBControl named 'Robot Dancing Music' does not exist. Can not send command 'stop'. 25.03.2017 08:42:04C:\Users\Stiko\Documents\EZ-Builder\My Projects\EZRI.EZBControl named 'Script Manager' does not exist. Can not send command 'ScriptStopAll'. 25.03.2017 08:42:04C:\Users\Stiko\Documents\EZ-Builder\My Projects\EZRI.EZBControl named 'Robot Dancing Music' does not exist. Can not send command 'stop'. 25.03.2017 08:46:27C:\Users\Stiko\Documents\EZ-Builder\My Projects\EZRI.EZBSaved C:\Users\Stiko\Documents\EZ-Builder\My Projects\EZRI.EZB 25.03.2017 08:48:17C:\Users\Stiko\Documents\EZ-Builder\My Projects\EZRI.EZBSpeech Synthesis Error (SayEZB): System.InvalidOperationException: Die Ausgabe des Synthesizers kann whrend des Sprechens nicht gendert werden. bei System.Speech.Internal.Synthesis.VoiceSynthesis.SetOutput(Stream stream, SpeechAudioFormatInfo formatInfo, Boolean headerInfo) bei System.Speech.Synthesis.SpeechSynthesizer.SetOutputToNull() bei System.Speech.Synthesis.SpeechSynthesizer.SetOutputStream(Stream stream, SpeechAudioFormatInfo formatInfo, Boolean headerInfo, Boolean closeStreamOnExit) bei System.Speech.Synthesis.SpeechSynthesizer.SetOutputToAudioStream(Stream audioDestination, SpeechAudioFormatInfo formatInfo) bei EZ_B.SpeechSynth.SayToStream(String msg) bei EZ_Builder.UCForms.FormSpeechSynthesis.WY9tZY539q1(Object , EventArgs ) 25.03.2017 08:49:06C:\Users\Stiko\Documents\EZ-Builder\My Projects\EZRI.EZBControl named 'Script Manager' does not exist. Can not send command 'ScriptStopAll'. 25.03.2017 08:49:06C:\Users\Stiko\Documents\EZ-Builder\My Projects\EZRI.EZBControl named 'Robot Dancing Music' does not exist. Can not send command 'stop'. 25.03.2017 09:04:56C:\Users\Stiko\Documents\EZ-Builder\My Projects\EZRI.EZBControl named 'Script Manager' does not exist. Can not send command 'ScriptStopAll'. 25.03.2017 09:04:56C:\Users\Stiko\Documents\EZ-Builder\My Projects\EZRI.EZBControl named 'Robot Dancing Music' does not exist. Can not send command 'stop'. 25.03.2017 09:19:17C:\Users\Stiko\Documents\EZ-Builder\My Projects\EZRI.EZBSaved C:\Users\Stiko\Documents\EZ-Builder\My Projects\EZRI.EZB 25.03.2017 09:58:18C:\Users\Stiko\Documents\EZ-Builder\My Projects\EZRI.EZBControl named 'Script Manager' does not exist. Can not send command 'ScriptStopAll'. 25.03.2017 09:58:18C:\Users\Stiko\Documents\EZ-Builder\My Projects\EZRI.EZBControl named 'Robot Dancing Music' does not exist. Can not send command 'stop'. 25.03.2017 09:58:29C:\Users\Stiko\Documents\EZ-Builder\My Projects\EZRI.EZBControl named 'Script Manager' does not exist. Can not send command 'ScriptStopAll'. 25.03.2017 09:58:29C:\Users\Stiko\Documents\EZ-Builder\My Projects\EZRI.EZBControl named 'Robot Dancing Music' does not exist. Can not send command 'stop'. 25.03.2017 10:03:42C:\Users\Stiko\Documents\EZ-Builder\My Projects\EZRI.EZBControl named 'Script Manager' does not exist. Can not send command 'ScriptStopAll'. 25.03.2017 10:03:42C:\Users\Stiko\Documents\EZ-Builder\My Projects\EZRI.EZBControl named 'Robot Dancing Music' does not exist. Can not send command 'stop'. 25.03.2017 10:05:55C:\Users\Stiko\Documents\EZ-Builder\My Projects\EZRI.EZBControl named 'Script Manager' does not exist. Can not send command 'ScriptStopAll'. 25.03.2017 10:05:55C:\Users\Stiko\Documents\EZ-Builder\My Projects\EZRI.EZBControl named 'Robot Dancing Music' does not exist. Can not send command 'stop'. 25.03.2017 10:12:16C:\Users\Stiko\Documents\EZ-Builder\My Projects\EZRI.EZBControl named 'Script Manager' does not exist. Can not send command 'ScriptStopAll'. 25.03.2017 10:12:16C:\Users\Stiko\Documents\EZ-Builder\My Projects\EZRI.EZBControl named 'Robot Dancing Music' does not exist. Can not send command 'stop'. 25.03.2017 10:14:34C:\Users\Stiko\Documents\EZ-Builder\My Projects\EZRI.EZBControl name
For me the EZ b default Ap mode works great for long range outside,I do not need a wi fi repeater and tested the robot around a large camping area,stayed connected very good. You can see the video I made testing the range at the forum page Recent community videos---"Rad robot ready for field investigating all by itself" The connection never had any error only problem was I need a stronger battery for the motor controller to make it drive longer time.
Germany
My WIFI signal is large. With my Handy i can recive 50m around my house. But when i have 50% with my handy, my robot has not enough signal and lost it. The large problem is the fat stonewall from this old house. Now I have install a repeater in the garden.
Thanks Roborad. I have test the AP-Mode. In the AP Mode i must go outside from the house. The range from my house outside is not very long. This house has to fat walls. So i have try the using from the repeater.
Thanks DJ-sure for this tip. Hmm, how i can see my errors from the last days? Some days ago, i have fixed a lot of Errors. I have update the onlineproject from my robot.
Yes it was very greasy and i was on the wrong way. I have use to many script from other peoples. Now i use the most own scripts with blockly. Its great.
The Bugwindow comes not so often. How i can see a log after restart ARC?
Thanks for your time.
During ARC, you can see the log at the bottom of the screen.
After ARC, you can look in the My Documents\EZ-Builder\Logs folder
Germany
I have try and check the log. I have actually no errors. But i lost the connection sometime.
In this log, at the last lines, my robot was one metre from my computer away. Connection is with a WLAN-Stick per EZB Network.
I see only networkerrors. When i use my robot with my phone. I have the same problems. The robot disconnect sometimes. I have no idea why. My phone was direct near from 2 metres away.
