Dialogflow icon Dialogflow — Add Google DialogFlow NLP to ARC: conversational intents, parameter prompts, scripted responses, service-account setup and programmatic robot control. Try it →
Germany
Google+ YouTube
Camera Question
Hello, I have a problem with the camera, and the EZB-V4. When the camera for a long time is in effect. Crashes the system.
Enough memory can not be the cause, I have 8GB Ram and including about 40% occupancy.
There come the following error messages: ezbv4 camera image render error: System.OutOfMemoryException: Nicht genügend Arbeitsspeicher. bei System.Drawing.Bitmap..ctor(Stream stream) bei EZ_B.Camera.tCkmJiIoL7(Byte[] ) bei EZ_B.EZBv4Video.aOBpWgc6y8(Object )
and another one:
Error Camera.SetCaptureImage: System.Exception: The _workerBitmap has not been initialized. Internal EZ-B Camera error. Please report this to EZ-Robot bei EZ_B.Camera.rMDmX0565k(Object ) Camera Initialized: EZB://192.168.1.1 @ 320x240
Those errors can occur from network timeouts - they show the camera has not been correctly shutdown, which implies an error upstream. If the camera is on for a long time, there are many other factors that can cause the issue - most common is wifi timeout or network interference.
Germany
Google+ YouTube
Hello Dj, thanks for the super fast response.
