Cognitive Vision icon Cognitive Vision — Microsoft Cognitive Vision integration for ARC: real-time object, face, emotion detection, OCR, confidence data and script-triggered robot actions. Try it →
Camera And Sound Servo Help
Hi guys! I have a camera on my robot, and I was wondering if you can record with it. If so, how do I do it? Also I really like using the sound servo, but every time I pause it, it breaks and I have to restart Ez builder to get it to work again. Is that something you are working on, or is it my computer? Thanks!:)
Sounds like a corrupt installation OR the path is incorrect OR the filename extension does not match the selected codec.
If that's the case, how would I fix it?
Good question. Localized issues are troublesome because every Windows issue is different. Let's start by sharing your project. That way I can see what settings are configured as a first step.
Use the attach file button to upload your project to your forum response.
Ok! I hope this goes though.
I had to lighten the file. Here it is.
#15
Thanks - i loaded the project without any issues recording video - although i did notice the video delay is set for 3fps, which won't effect the recording but it sure is slow:). I'm unsure why you receive that error message while attempting to record video. I will add additional debug information to the recording method to see if we can get a better error out of your experience for the next release of ARC.
In the meantime, i can suggest you can perform the following...
  1. uninstall ARC
  2. reboot the PC
  3. download and re-install ARC
see if that process helps. It's really difficult to identify localized issues like this. But we'll figure it out:)
#16
Ok. Yeah it must be my computer then. Does it save the video anywhere?
