how do u connect a BlinkM to an ez-b? or do you not connect it at all?
SM
— Edited
Custom Movement Panel V2
— Custom Movement V2 panel for ARC: scripts for F/R/L, Reverse, roll left/right, up/down with speed mapping to PWM for drones, mecanum & custom drives
The BlinkM is an I2C device so therefore you connect it to the I2C port.
If you have a V3 EZ-B it will plug directly in to the I2C port if you want to or you can run wires to it if it's away from the board.
If it's a V4 you can connect to any of the three I2C ports.
it works!
