Read Digital icon Read Digital — Read TTL digital input from an ARC I/O port; real-time red/green status for low (0V) or high (+3.3/5V), selectable board/port and read interval. Try it →
Bing Vr Start Button
I'm having an issue with starting Bing to listen right after ARC starts. I cant start it listening by clicking the Start Recording button or starting it from an EZ Script with the start listening command.
The only way I can get the control to start recording is to go into it's settings page and click on the Save button. Then when I exit back to the front of the control everything is working right. The control will continue to work correctly until I restart ARC. Then I need to do the above all over again.
Any ideas what may be going on here? I turned my Windows Defender off but nothing changed. I have no other antivirus running.
I'v attached a Youtube vid of what is happening.
Thanks!
#17
Ok thanks Dave, I will dig deeper and install the updates to see. I get 2 keys from Microsoft and I'm using key 1, going to try key 2 and see if it makes a difference . Thanks again Dave.
#18
Merne, I already tried the 2nd key. No change. MS provides the 2nd one so you can change it for security reasons without service Interruptions.
#19
Dave, I install the updates and everything is working now I'm not sure if it was just me? Might have been as some of this is just too techie for me. Thanks again!
And of course thanks to Dj for the updates!
#20
OK Great! My Bing Start Recording button is working properly now. Now more need to click the Save Button after each ARC restart. Many thanks DJ for the plugin update. :D
