Alternative to ezrobot ezb for robot head project
Alternative To Ezrobot Ezb For Robot Head Project
My course has primarily focused on robotics projects using the EZ-B controller and a camera for real-time interfacing. With recent developments, I am planning to create an additional video that incorporates Synthiam's support for other types of controllers. Although I've successfully flashed an alternative controller, it lacked compatibility with camera integration and Wi-Fi capabilities. The absence of an onboard computer limits the use of a USB camera, posing a significant challenge.
This dependency on specific components like the EZ-B, IO Tiny, and cameras can be problematic. For my course project, Mecha Morphix, which involves controlling five servos, the Arduino Mega seems excessive. I am in search of a suitable controller, compatible with Synthiam ARC, that includes both Wi-Fi and camera support to effectively replace the EZ-B.
I noticed that the ESP32 with a camera is listed among the supported controllers for ARC. Has anyone experimented with using the ESP32 in conjunction with a camera for such applications? Any insights or experiences would be appreciated.
ESP32 Cam by Espressif
Servos Varies
UART Varies
ADC Varies
Digital Varies
ESP32_MPU6050 by Shawn Miller
ESP32/Arduino EZB firmware with MPU6050 support: provides accelerometer angles and Yaw/Pitch/Roll gimbal servo values for stabilization and scripting
Bridge ARC to Lynxmotion SSC-32: maps V0-V31 to SSC-32 channels for reliable, high-performance serial control via USB, EZB/Arduino UART.
#201   — Edited
Haha I’ll take the beers thanks.
did you try v13? Did it make a difference?
ESP32 Cam EZB firmware
for ESP32 Cam by Espressif
Transform ESP32-CAM into an EZ-B for Synthiam ARC: simultaneous video streaming and servo control in a compact, cost-effective solution.
Firmware Versions 13
Last Updated
Current Version v13
Hardware ESP32 Cam
#202
Ran out of time last night. Will test today after I drop off my kids to school.
#203   — Edited
No rush on this at all. Just getting around to trying ver 13.
  • ESP32-Cam (ver 13)
  • ARC ver 2.19.01
  • SSC-32
  • After I connect to the ESP32, I can move a servo on the SSC-32
  • After I connect camera frame is frozen and camera drops with error message in the video. (new)
  • The connection to the ESP 32 soon after drops as well. (new)
ARC error message is a s follows:
Connected TCP Comm Error: Unable to write data to the transport connection: An existing connection was forcibly closed by the remote host. Sent: 4 6 9 0 35 48 80 49 52 57 52 13 10 Bytes Expected: 0 Received (0 bytes): Disconnected
#204   — Edited
...having alot of trouble with posting BTW...
#205
Ok after reading your update thread about the road ahead for the ESP-32s I am going to abandon making a Mega EZB with the SSC-32.
What would be cool is if there is a way to daisy chain the PCA9685's together to extend the ports out.
We're already in great territory with the single ESP32-CAM and PCA 9685 combo if nothing else changes.
