DJ/EZ-Robot,
What software IDE do you use to build the EZ Robot software? What language do you use?
Do you use any 3rd party add-ons or DLL, like OpenCV?
Thanks, Keith
Remote UI Client
— PC Remote UI Client for ARC enables remote robot control via customizable multi-page interfaces from other ARC instances.
DJ/EZ-Robot,
Thanks, Keith
Hi Keith - the ARC software was originally built in C++ and eventually ported to C#. With Microsoft's recent move to opensource .Net, this helps for portability between devices. The ARC Mobile and ARC PC are able to share essential libraries for the EZ-Script Compiler and a variety of other features.
The EZ-SDK is the base of all EZ-Robot Software. The EZ-SDK contains a few third party libraries, such as ffmpeg and a modified AForge.Net. For the audio MP3 decoding, the NAudio library is used.
OpenCV is not used - but you can use it, such as the EZ-Face can be used as an example - which uses OpenCV.
