Auto Position (Gait) icon Auto Position (Gait) — Create servo frames and actions to animate gaits and gestures with automatic motion planning, software ramping, movement panel, import/export Try it →
Going to need more info than that dude.
What are the issues? What controls? Post the project file?
If you are talking about the script (that I just noticed as I closed the image) then you need to check the syntax of the script. EZ-Script syntax changed a few updates ago and it looks like you have text that is not enclosed in quotes (which is now a requirement for all text) on line 12. The debug of the script should tell you everything you need to know on that one.
A few months ago the EZ-Script was changed to require proper use of strings. This means surrounding commands in quotes "like this"
Roomba( "init" )
Roomba( "MainBrushOn" )
Thats what I needed. Thanks DJ been a while since I got a chance to sit down with this again. And just moved everything to my new pc. Ok a few mods to my script all good.
Don't forget to mark as answered if it has been:)
Thanks Guys.
