Ez430-Chronos Wrist Watch icon Ez430-Chronos Wrist Watch — Map TI eZ430-Chronos watch accelerometer X/Y tilt to ARC servos for intuitive, Wii-Remote-style control of servo positions. Try it →
ARC On Microsoft Surface Book
I have a microsoft surface book with windows 10 professional. Finally made the switch from windows 7.
I have read the threads on display issues with windows 10. I have the screen resolution set to 1920 x 1080 with a text size of 125. Everything displays in one screen without having to scroll left or right. Text displays fine but is a bit small.
Just wondering what settings others are using with the microsoft surface book to maximize the capabilities of both ARC and the surface book laptop? Am I using the optimal settings on laptop for ARC ? Thanks for any comments.
You can always increase the text size as much as you want - but remember, the larger the text, the more room the text occupies. So pure logic here, larger text means less room for anything else. Also, sometimes there won't be enough room for the text to display if it is too large, so the text may be cut off. All common sense stuff, but i mentioned it so it's not overlooked
have fun!
