Hi, I received my kit and I have been loving it...until I slipped a bit and blew one of the 220uf 6.3 capacitors (Thankfully I had my safety glasses on because the cap rocketed off). The board is still functioning but I want to swap the capacitor. My local shops only carry a 220 10v and I was wondering if that was an acceptable solution or should I swap out equivalent specification parts?
mattkulcsar
— Edited
That capacitor you listed will work
Are you putting voltage back into the ez-b connectors?
Thanks for your quick response! Yes, I was using an off-the-shelf 7.2v rechargeable battery pack to hook up the EZ-B to power the Rover 5 I purchased from your site. I don't know if I was sloppy and allowed unintentional contact but the sequence went:
This all happened in the matter of a second.
Side note: Huge fan of yours, keep up the great work!
Thank you
Glad to hear your board is still working after that. Looking forward to seeing what you build
Is there any place I can secure instructions on the best way to hook the EZ-B to the Rover 5? I looked at most of the videos but I can't find the information I need. Thanks for your help, Matt
Hello Matt, are you referring to an electrical hookup between EZ-B and the Rover? As I understand, the only connection is via the wireless stream between your PC/ARC and the Rover. There is no wiring required between the EZ-B and Rover.
Physically placing the EZ-B onto the Rover is so that you can hook up sensors and whatnot to the EZ-B and utilize them (via the Bluetooth link between EZ-B and your PC) in relationship to the Rovers environment.
And as far as a physical connection goes... duct tape works
actually I would use plastic/metal standoffs and somehow affix them to the Rover (glue?). That way it is secure when driving, but easily removable. As for power, I suppose you could tap into the Rovers power? as long as it has enough voltage (6v-18v) or just attach the AA battery pack (or your 7.2v pack) to the Rover as well.
You know... it just dawned on me that you might be referring to the rover chassis in the EZ-Robot store, and NOT the Brookstone Rover as I was assuming blush I just looked and it is actually referred too as a "Rover 5" (I thought the "5" was a typo in your post) My bad
In that case... that is a whole different story
You cannot power it's motors directly off the EZ-B ports, you need a H-Bridge controller for that. That might have been the cause of your original issue.
Check out this Tutorial for the the H-Bridge sold in the EZ Store
2.5 Amp Motor Controller
Yup gunner is right . Fyi those motors on rover draw up to 4 amps at stall .
Wow, I really appreciate the thorough information provided. Yes I was talking about the Rover 5 and after doing some pencil work and research I came to that same conclusion that I needed the h-bridge. Right now I have a kooky hookup through an Anduino board with a Motor Shield until my wife allows me to spend more money on my hobbies. I'm wearing her down and should have it soon
Thanks again!
