PTI Lidar Plugin icon PTI Lidar Plugin — Pineapple Technology Industries Capstone plugin adds a secretive LiDAR unit to ARC for distance measurement. Try it →
A Bug Of Speech Synthesis
system version:win8.1 (simplified Chinese)
EZ building version:V16.6
phenomenon:if I select "say(EZ-4 speaker)"at the start, everything is absolutely normal,my robot can speak in English or Chinese.But after that I click "say PC speaker" once,then select "say(EZ-4 speaker)" again.I will get an unhandled exceptions error message. There have been repeated attempts,I still got the same results.
Not sure what could be causing that, maybe a Windows issue. You could try reinstalling ARC and try it again. Do you have the latest update?
It is most recent version of the software I just installed. In fact,if as long as I do not click ""say PC speaker",do not affect use.
Okay. Hopefully somebody else will jump In with a possible solution.
Sorry I can't be of any more help.
I got the detailed information.But I am sorry,DJ.My system is chinese version,so the message was displayed in Chinese.as follow.
BTW:I found when I make robot disconnect from PC,then I repeated the steps above.I got the same error and software had to quit.That is,whether I make robot connect with PC or not,this error is generated.So I think it is a obvious bug.
??????(JIT)??????????????, ??????????
************** ???? ************** System.InvalidOperationException: ?????????????? ? System.Speech.Internal.Synthesis.VoiceSynthesis.SetOutput(Stream stream, SpeechAudioFormatInfo formatInfo, Boolean headerInfo) ? System.Speech.Synthesis.SpeechSynthesizer.SetOutputToNull() ? System.Speech.Synthesis.SpeechSynthesizer.SetOutputStream(Stream stream, SpeechAudioFormatInfo formatInfo, Boolean headerInfo, Boolean closeStreamOnExit) ? System.Speech.Synthesis.SpeechSynthesizer.SetOutputToAudioStream(Stream audioDestination, SpeechAudioFormatInfo formatInfo) ? EZ_B.SpeechSynth.SayToStream(String msg) ? EZ_Builder.UCForms.FormSpeechSynthesis.KQnhhkMZ1xM(Object , EventArgs ) ? System.Windows.Forms.Control.OnClick(EventArgs e) ? System.Windows.Forms.Button.OnClick(EventArgs e) ? System.Windows.Forms.Button.OnMouseUp(MouseEventArgs mevent) ? System.Windows.Forms.Control.WmMouseUp(Message& m, MouseButtons button, Int32 clicks) ? System.Windows.Forms.Control.WndProc(Message& m) ? System.Windows.Forms.ButtonBase.WndProc(Message& m) ? System.Windows.Forms.Button.WndProc(Message& m) ? System.Windows.Forms.Control.ControlNativeWindow.OnMessage(Message& m) ? System.Windows.Forms.Control.ControlNativeWindow.WndProc(Message& m) ? System.Windows.Forms.NativeWindow.Callback(IntPtr hWnd, Int32 msg, IntPtr wparam, IntPtr lparam)
************** ??????? ************** mscorlib ?????:4.0.0.0 Win32 ??:4.6.96.0 built by: NETFXREL2STAGE ????:file:///C:/Windows/Microsoft.NET/Framework/v4.0.30319/mscorlib.dll
EZ-Builder ?????:2015.8.9.0 Win32 ??:2015.10.09.00 ????:file:///D:/Program%20Files%20(x86)/EZ-Robot%20Inc/ARC/ARC.exe
PresentationCore ?????:4.0.0.0 Win32 ??:4.6.81.0 built by: NETFXREL2 ????:file:///C:/windows/Microsoft.Net/assembly/GAC_32/PresentationCore/v4.0_4.0.0.0__31bf3856ad364e35/PresentationCore.dll
WindowsBase ?????:4.0.0.0 Win32 ??:4.6.81.0 built by: NETFXREL2 ????:file:///C:/windows/Microsoft.Net/assembly/GAC_MSIL/WindowsBase/v4.0_4.0.0.0__31bf3856ad364e35/WindowsBase.dll
System ?????:4.0.0.0 Win32 ??:4.6.81.0 built by: NETFXREL2 ????:file:///C:/windows/Microsoft.Net/assembly/GAC_MSIL/System/v4.0_4.0.0.0__b77a5c561934e089/System.dll
System.Windows.Forms ?????:4.0.0.0 Win32 ??:4.6.81.0 built by: NETFXREL2 ????:file:///C:/windows/Microsoft.Net/assembly/GAC_MSIL/System.Windows.Forms/v4.0_4.0.0.0__b77a5c561934e089/System.Windows.Forms.dll
System.Drawing ?????:4.0.0.0 Win32 ??:4.6.93.0 built by: NETFXREL2STAGE ????:file:///C:/windows/Microsoft.Net/assembly/GAC_MSIL/System.Drawing/v4.0_4.0.0.0__b03f5f7f11d50a3a/System.Drawing.dll
EZ_B ?????:2015.7.28.0 Win32 ??:2015.09.20.00 ????:file:///D:/Program%20Files%20(x86)/EZ-Robot%20Inc/ARC/EZ_B.DLL
System.Configuration ?????:4.0.0.0 Win32 ??:4.6.81.0 built by: NETFXREL2 ????:file:///C:/windows/Microsoft.Net/assembly/GAC_MSIL/System.Configuration/v4.0_4.0.0.0__b03f5f7f11d50a3a/System.Configuration.dll
System.Core ?????:4.0.0.0 Win32 ??:4.6.81.0 built by: NETFXREL2 ????:file:///C:/windows/Microsoft.Net/assembly/GAC_MSIL/System.Core/v4.0_4.0.0.0__b77a5c561934e089/System.Core.dll
System.Xml ?????:4.0.0.0 Win32 ??:4.6.81.0 built by: NETFXREL2 ????:file:///C:/windows/Microsoft.Net/assembly/GAC_MSIL/System.Xml/v4.0_4.0.0.0__b77a5c561934e089/System.Xml.dll
System.Speech ?????:4.0.0.0 Win32 ??:4.0.30319.33440 built by: FX45W81RTMREL ????:file:///C:/windows/Microsoft.Net/assembly/GAC_MSIL/System.Speech/v4.0_4.0.0.0__31bf3856ad364e35/System.Speech.dll
EZ-RibbonMenu ?????:2015.7.3.0 Win32 ??:2015.07.03.0 ????:file:///D:/Program%20Files%20(x86)/EZ-Robot%20Inc/ARC/EZ-RibbonMenu.DLL
Accessibility ?????:4.0.0.0 Win32 ??:4.0.30319.33440 built by: FX45W81RTMREL ????:file:///C:/windows/Microsoft.Net/assembly/GAC_MSIL/Accessibility/v4.0_4.0.0.0__b03f5f7f11d50a3a/Accessibility.dll
mscorlib.resources ?????:4.0.0.0 Win32 ??:4.6.81.0 built by: NETFXREL2 ????:file:///C:/windows/Microsoft.Net/assembly/GAC_MSIL/mscorlib.resources/v4.0_4.0.0.0_zh-Hans_b77a5c561934e089/mscorlib.resources.dll
System.Xaml ?????:4.0.0.0 Win32 ??:4.6.81.0 built by: NETFXREL2 ????:file:///C:/windows/Microsoft.Net/assembly/GAC_MSIL/System.Xaml/v4.0_4.0.0.0__b77a5c561934e089/System.Xaml.dll
FFMPEG ?????:2013.8.13.0 Win32 ??: ????:file:///D:/Program%20Files%20(x86)/EZ-Robot%20Inc/ARC/FFMPEG.DLL
Microsoft.GeneratedCode ?????:1.0.0.0 Win32 ??:4.6.81.0 built by: NETFXREL2 ????:file:///C:/windows/Microsoft.Net/assembly/GAC_MSIL/System.Xml/v4.0_4.0.0.0__b77a5c561934e089/System.Xml.dll
System.Speech.resources ?????:4.0.0.0 Win32 ??:4.0.30319.33440 built by: FX45W81RTMREL ????:file:///C:/windows/Microsoft.Net/assembly/GAC_MSIL/System.Speech.resources/v4.0_4.0.0.0_zh-Hans_31bf3856ad364e35/System.Speech.resources.dll
System.Windows.Forms.resources ?????:4.0.0.0 Win32 ??:4.6.81.0 built by: NETFXREL2 ????:file:///C:/windows/Microsoft.Net/assembly/GAC_MSIL/System.Windows.Forms.resources/v4.0_4.0.0.0_zh-Hans_b77a5c561934e089/System.Windows.Forms.resources.dll
************** JIT ?? ************** ?????(JIT)??, ?????????? .config ??(machine.config)? system.windows.forms ?????? jitDebugging ?? ???????????? ???
<configuration> <system.windows.forms jitDebugging="true" /> </configuration>
?? JIT ???,????????? ??????????????? JIT ???, ???????????
I feel very bad.When I click "send" button,I got a new unhandled exception error message.I re-installed ARC,but the question remained.
