QR Code Generator icon QR Code Generator — Create customizable QR codes for ARC, display/scan via Camera Control, trigger scripts on recognition and save decoded text to variables. Try it →
Blown 5A Regulator I/O
Thought I'd post this just to help out.
Recently I was working with two Pololu 18/7 simple motor controllers and the EZ-B. After some configuration with the Pololu software I got the controllers working with the EZ-B.
I decided to try to calibrate the left controller as it didn't feel like the right while I tested it in the servo panel. After getting it calibrated again, I plugged it back in to D12 while the power was still applied to both the motor controller and the EZ-B. Simple, or so I thought. I missed the pin orientation on the servo (Motor controller) plug and shorted positive to negative. The 5a I/O regulator let out a pop and a cloud of smoke. No more 5vdc at the servo pins. The included fuse didn't blow first. I unsoldered the LM1084 regulator and without paying close attention, order replacements. Here's what I learned: The regulator is availabe in several forms all bearing the LM1084 prefix. If this happens to you, make sure you order the LM1084-5. I ordered 10 of the LM1084-adj. Big mistake! The versions: LM1084-3.3 LM1084-5 LM1084-12 LM1084-adj
I had to reorder the correct -5 designation so my bot sits and waits again.
I hope this helps someone out there if they have the same problem.
Cheers!
Sorry to hear about your "smoked" experiance:( and then double bad about ordering the incorrect regulator......but thank you so much to post the caveats! an incorrect number ..or letter can make for a bad day:( what did the "adj" mean? and why wouldn't work?
The suffix "adj" stands for adjustable voltage and the circuit for this version is just a bit different. This has been a learning experience for sure!
The voltage output is variable based on the collector pin voltage I believe.
