Brushless Motor Movement Panel icon Brushless Motor Movement Panel — Control brushless motor controllers (hoverboard-style) via EZ-B: configure direction, speed and optional brake ports for DIY robot movement. Try it →
We have arranged a quicker shipping method now yah. The current orders have taken 4-5 days. We're much happier with the new service:)
Okay, I just placed my order. How do you run two EZ-B's at the same time? Just add two blue tooth devices?
Add each EZ-B to your computer, just like you did with the first one. Right click -> Add Device etc..
Then in ARC, you have drop downs for all 5 EZ-B's. In each control there is now a drop down to select what EZ-B it connects to.
For scripting, you put the EZ-B board number in front of the command. If there is no number in front of the command, it assumes board 0
# this will move servo D0 to position 5 on EZ-B 0
servo(d0, 5)
# this will move servo D0 to position 10 on EZ-B 3
3.servo(d0, 10)
