is it possible to convert Blockly to EZ-script? I have a good routine I want to use that I created in Blockly, but it needs a few tweeks that I need to add in EZ-Script.
edbot
— Edited
Yes. Push the EZ-Script tab and view the generated code and editable in EZ-Script. Remember that it's one way. You can't generate Blockly from ez-script.
Thank You, that was easy. I had started on the script with Blockly using the f9 on the File overview page. which only has a code tab that does not let you edit.
you guys are the best!!
