Train Vision Object By Script icon Train Vision Object By Script — Train camera vision objects via controlcommand(), attach camera, start learning, monitor progress, and return object name for scripts. Try it →
Are you asking about this HDD Servo? If so, the specs are posted on the product page - also there is a bag of servo horns included. Here's the specs for ya!:)
[feature] Features Operating speed: 0.24sec/60degree (7.4V) Stall torque: 15.0kg-cm/529 oz-in.(7.4V) Temperature range: -20C to +60C Operating voltage: 4.8V to 7.4V 3 pole ferrite Dual ball metal bearing All metal gears Connector wire length: 32cm Futaba 3f (25 teeth) for driving spline/shaft 6.2mm spline (including teeth) [/feature]
Thanks! I didn't even think to check the specs for the servo, lol. I suffer from sporadic brain farts.
Ha - first step is admitting:D
