Touch Path icon Touch Path — Sketch paths with finger or mouse and set turn/move speeds; interactive, educational demo of timing-based, sensorless robot navigation and limits. Try it →
Where Is The Ez-B Manual?
Hey guys,
In the early days of EZ-Robot, I think a manual in a PDF form, was easily access on this site. Where is it? The one the site now is not what Im looking for. I need some answers for the questions: If anyone could help, that be great..
Max current/amp: 5amp? hence the 5amp fuse
Max current/amp on a single I/O:
DC current per I/O pin:
Minimum operating voltage:
Maximum operating voltage:
Operating voltage:
Input voltage (recommended): 7.5v?
I just looking to see if I could use the EZ-B as an ON/Off switch and a Power supply for my lighting system. My system takes 5V max to operate but I dont know the amps but I have to use a 9 volt battery and a Pololu step-down voltage regulator D15V35F5S3 https://www.pololu.com/catalog/product/2110 to get it working. Im guessing 3.5amps but
thanks Im guessing
