After I finish the assembly of the JD,and then connected to the JD through the ARC.But the right server seems to have a problem with the termination of the initial,as shown in Figure.I can hear the sound of the right foot server,and it's going to get hot.How do I get my robot to dancing and singging? Please help me,thanks a lot!
Lei Hang
China
— Edited
It sounds like you don't have the servos adjusted properly. Please read all the tutorials on setting up JD and follow them as shown.
Also to make him dance and sing make sure you have the proper JD Project loaded in ARC.
Start in the Learn section: synthiam.com/Tutorials/
Good luck.
As dave said, sounds like your robot is working fine but it requires calibration. Follow the tutorials on the JD page to get up and running: https://synthiam.com/Tutorials/Course/1
The instructions for dancing, singing and assembly are in the tutorial. Every servo must be connected to the correct location on the EZ-B. If the servos are not connected to their correct location, the JD robot will not function and may be damaged. Please follow the tutorial for JD here: https://synthiam.com/Tutorials/Course/1
If by chance you need to physically calibrate the servo, it can be found in the tutorial. Here's a direct link: https://synthiam.com/Tutorials/Lesson/29?courseId=1
Everything you will need for JD can be found in the tutorial, here: https://synthiam.com/Tutorials/Course/1
Have fun!
Thank you all,extremely grateful. The problem is that I need to calibrate the servo motor.The angle need to calibrate is too large, so I am at a loss.Your reminder let me solve my problem. Good luck!
If the angle is too large, the servo bracket may be aligned manually: https://synthiam.com/Tutorials/Lesson/29?courseId=1
Enjoy!
