Virtual Reality Robot icon Virtual Reality Robot — Stream robot camera to VR and control servos with headset pitch/yaw; supports SteamVR and Cardboard (iOS/Android) for immersive teleoperation Try it →
Vr Options?
Does anyone know if the SDK of the Oculus Rift package would work with EZB if there was a plug in developed for it? It doesn't really need to be something as big and bulky as that. Very unfortunate that Vuzix is no longer offering support with EZB. That would work great.
Like the Vuzix, I'd like to pull from the IMU data to move servos and transfer the camera feed from the EZ camera to the goggles over two complete separate computers in different places.
Any ideas or suggestions on how to POC this, would be grateful.
#241
Files have been deleted, read your email.
#242
@Nick Yes BioIK is great, it helped us a lot to get full IK running on our robotics project, Sebastian Starke the author is a great guy. I was not aware that uploading the Unity scene might end in the misuse of his work. I paid for the plugin and I would like anyone using it to do the same to respect his work!
So please remove the link from post #223
#243
@all This is great, now the biggest challenge is done...Full IK is being transfered realtime to the EZ-B! THIS IS AWESOME!
I could not resist to laugh a little when I saw the clip of poor JD, because the IK setup is terrible...I was uploading the scene in a rush, just for POC so we can get things going! This setup is far far away from being usable!:D
I changed the rotation limits within BioIK so they are all range from -90/+90, this is where the mysterious +90 is originating from... I made this to have consistency in servo degrees, but the IK setup has to be changed to make JD move the way we want him to move, and not look like somebody broke his arm!:D
Also the Grippers do not belog to the IK Chain...I guess the best option will be to either make a slider for opening an closing the Grippers, or attach them to left/right Mouse buttons for live control!
#244
So the next step will be to have a neat IK setup for JD, including Gripper control...which is a good thing, we will learn a lot about hooking things up in Unity and on how to properly use BioIK!
Another thing we need to start thinking about are the leg controls for JD, we should try to setup the rig in a way that the feet are reacting to the ground...BioIK has examples on how to do this, I have not looked into them yet.
And at last we should make a standalone application so everyone owning a JD will be able to drive his real JD using the Virtual JD we created! I guess we would need a text field to put the IP address, and we will have to take care that our servo wiring is corresponding to the real life JDs wiring!
Great progress this is huge!:D
edit Just checked the new revision of the script, and @ptp thoughtfully included the naming convention for JDs servo setup!
#245
I checked the script and everything works as expected...this is such a great leap forward! Lets keep on developing the Virtual JD!:)
Twitter
#246
Thanks @PTP I will test tonight after work. I updated my post.
#247
So we should now have control for min and max and also inverting the servo direction within the plug in? Are we completely bypassing the ARC? Or will any constraints we set in ARC on servos be adhered too?
#248
Also is the script just built for JD, or is it universal for any character? In other words will we need to make a new script for every new character like Six?
