ADC Meter— ADC VU meter displaying 0-3.3/5V as a 0-255 linear meter; configurable board/port, sampling interval and color; pausable real-time readings.Try it →
Take it completely apart. Remove its brain and use either servos in place of the original motors or you can use a h bridge to control the motors. Then have fun playing with it through ezb...... I gave you the short answer your best off posting your project and pictures and when you take it apart document everything so we can help you through your project. Have fun! - Josh
ThinkGeek used to sell a USB missile launcher that had a .NET SDK. The current one they sell doesn't specify in the specs whether or not it has an SDK. If your launcher does, you might be able to do it all just in scripting. You can access .NET external components from within EZ-B scripts.
