Set Digital icon Set Digital — Toggle a digital I/O port between TTL low (0V) and high (3.3V/5V) in ARC; select board and port, simple on/off control-signal only. Try it →
Suggestion: Add Text Search Box In Script Help Window
I want to suggest adding a text search box at the top right of the Script Help window or add support for Control + F for text search. This will make it a lot easier to find the function you're looking for by entering a search term and press enter, much better than scrolling thru the list if you already know what you want and just need the command list.
