Speech Recognition icon Speech Recognition — Windows Speech Recognition skill: detect custom phrases via PC mic, trigger configurable scripts/actions with adjustable confidence. Try it →
Something Wrong When I Connect ARC To My Jd Robot
Hi all,
Since I've configured my EZ-B v4 to my wifi (D-link router), when I launch EZ-buider application and connect it, it freez, I've to kill the application to defreez it.
Here's the log:
2015-02-22 16:20 - Welcome to EZ-B v4 Beta! here I click on connect and it freez 2015-02-22 16:20 - *Warning: There is 1 bytes of unexpected data available on the TCP connection... Clearing. This can happen when the EZ-B is underpowered or connected attempted by multiple clients. 2015-02-22 16:20 - Unexpected Data: 4 2015-02-22 16:20 - *Warning: There is 1 bytes of unexpected data available on the TCP connection... Clearing. This can happen when the EZ-B is underpowered or connected attempted by multiple clients. here i've to kill the task to unfreez it 2015-02-22 16:20 - Unexpected Data: 4 2015-02-22 16:20 - EZ-B v4 ID: 56-53-0-0-47-255-59-57-61-38-38-38 2015-02-22 16:20 - Connected 2015-02-22 16:20 - Setting battery monitor voltage: 6.6 2015-02-22 16:20 - Setting battery protection: True 2015-02-22 16:20 - Setting i2c rate: 100000
I notice that : *Warning: There is 1 bytes of unexpected data available on the TCP connection... Clearing. This can happen when the EZ-B is underpowered or connected attempted by multiple clients.
I don't understand....
Thx for any help confused
To be clear is your ezb in WP (blue LED) or Client mode (green LED)... If it is in client mode did you use the scan tool to locate your ezb on your network? Then try and connect to that IP address? It will have a unique IP address if it is in client mode so not the default 192.168.1.0 or whatever... Have you tried downloading and reinstalling a fresh copy of ARC? Have you tried rebooting your router as well?
It's in Client mode (green LED)
I've try to reinstall ARC and reboot the PC as well, no change.
The only thing which work it's to create a new project : EZB 0: EZB 1: EZB 2: EZB 3: EZB 4: 2015-02-22 16:44 - TCP Server stopped 2015-02-22 16:44 - TCP Server stopped 2015-02-22 16:44 - TCP Server stopped 2015-02-22 16:44 - TCP Server stopped 2015-02-22 16:44 - TCP Server stopped 2015-02-22 16:44 - TCP Server stopped 2015-02-22 16:44 - TCP Server stopped 2015-02-22 16:44 - TCP Server stopped 2015-02-22 16:44 - TCP Server stopped 2015-02-22 16:44 - TCP Server stopped 2015-02-22 16:44 - Camera Initialized: EZB://192.168.0.106 @ 320x240 2015-02-22 16:44 - Object Recognition loaded. 2015-02-22 16:44 - Attempting connection on 192.168.0.106:23 2015-02-22 16:44 - Connected to 192.168.0.106:23 2015-02-22 16:44 - EZ-B reports EZ-B v4 OS 2015-02-22 16:44 - Welcome to EZ-B v4 Beta! 2015-02-22 16:44 - EZ-B v4 ID: 56-53-0-0-47-255-59-57-61-38-38-38 2015-02-22 16:44 - Connected 2015-02-22 16:44 - Setting battery monitor voltage: 6.6 2015-02-22 16:44 - Setting battery protection: True 2015-02-22 16:44 - Setting i2c rate: 100000
If you have to create a new project then maybe you can try and "merge" in all the controls from the JD sample project... See if that works?
There the same probleme after done the merge.
So there's something wrong in my main project.
So you have no issues with new projects, just with the JD sample Project? I think then maybe DJ needs to help you out with this....
Is the I2C RGB Animator connected correctly? The EZ-B will hang on I2C errors.
I've merge diifrent things one after one and test, and now it's ok.
So I've rename replace the old project by the new.
I think it have been corrupted but I don't no why...
Anyway, it's working again great now.
Thx a lot for your idea of merging :D
Yes rich, RGB was correct, thx
