PCA9685 Servo Driver icon PCA9685 Servo Driver — Drive 16 servos over EZB I2C with a PCA9685 PWM controller, using ARC servo commands and hardware-timed outputs. Try it →
Netherlands
Sdk For Mobile Development?
Hello,
I have been playing around with the EZ-SDK for Windows for some time. I prefer building apps using c# rather than the ARC because of the limitless possibilities. However, now I am at a point where I'd like to build a mobile app (more specifically for Android) rather than just for Windows.
The only way I've found so far as to integrate an EZ-Robot with Android is through the use of the Mobile Interface Builder in the ARC. This is however still limited as compared to what is possible through the use of programming language, where you can import countless external libraries or make use of the underlying Operating System.
So my question is: Is it possible to write Apps that work on Mobile Platforms (at least Android) similarly as to how you would do it when a program using the Windows SDK?
Thanks in advance.
Use Xamarin combined with ezrobot mono sdk. This is how the current mobile app is built. All development options can be found under the software tab on this website.
Here’s a direct link to save you the clicks: https://synthiam.com/Products/ARC
Have fun:)
Netherlands
Thank you for your answer. Xamarin + the Mono SDK was just what I was looking for.
