Hitachi-LG LDS Lidar icon Hitachi-LG LDS Lidar — Hitachi-LG LDS 360-degree LiDAR driver streaming scans into ARC NMS for obstacle detection, SLAM use, Arduino hookup, config options and variables. Try it →
Remotely Power On Or Off Revolution Robots?
Hello - I am mostly paralyzed from Lou Gehrig's disease and I won't be able to turn my Roli on or off to use it when I am home alone. My house is fully automated so I can be left alone for a few hours at a time. Is there a plan or a way to do this seemingly simple task? Robotics for the disabled is a largely untapped field. I performed a few searches but came up empty. Thank you in advance for your replies.
40 mA? At idle? That's lower than I thought. ..
It sounds like an adaptation is in the near future! The ability to do this would be a huge deal for me and it sounds as if there is some interest in the community. To give an example of how I envision using the Roli is, someone comes to my door, I turn on, or wake up Roli and drive him to the door which is opened using a remote controlled door opener, I can now see and speak to the person at the door. They will freak out by being greeted by a robot! It will be AWESOME! Thank you! I have a friend that is in the electronics field that helps me with this stuff. He is always wondering what I will come up with! He won't see this coming, if I need any help!
The lower power mode is enabled when there are no devices connected. It's a feature of the EZ-B v4:)
Also, due to the power supply being a Switching Power Supply, there is no heat during idle - therefore low energy consumption.
In this video, I talk a bit about the power supply that we created...
Wonderful! I would have my caregiver turn it on before she leaves, connect to it when I want or need to use it and disconnect when I am through and it is in low power mode. Brilliant!
Gotta luv that low power consumption in the EZ-4. Revolution is also ..."green" awesome DJ
Hi stelmobarry and everyone else.
Funnily enough I had a similar thought to you, of doing something along these lines on my current build. I don't have my EZ-B v4 just yet but expecting it soon, so I have not had the chance to physically look at one. Can someone tell me how the EZ-B4 power button works, i.e is it a click ON/click OFF switch or a momentary ON/OFF switch?
I did some web searching and came across this on the Amazon UK site, something similar to what thetechguru found which I was curious about. Remote control switch
Does anyone know, could something like this be connected to the EZ-B power switch or even bypass the switch completely and play nice with each other? Obviously it will need it's own power supply but a battery should last a long time between charges. If this was to work it would be a relatively simple and inexpensive fix to create a neat and useful feature for robot users from all walks of life.
Steve.
#15
The V4 doesn't have a power button itself. I believe the revolution robots have power switches though.
The power switch/button on a custom build could be anything you want it to be. I have a simple toggle switch on one bot, Melvin doesn't have a switch at all and my test bot I just unplug the battery to shut it down.
#16
In basic terms, the V4 board doesn't have an on/off switch... just a standard 2.1 barrel plug connector... Plug it in and it powers up...
