Hello - I am mostly paralyzed from Lou Gehrig's disease and I won't be able to turn my Roli on or off to use it when I am home alone. My house is fully automated so I can be left alone for a few hours at a time. Is there a plan or a way to do this seemingly simple task? Robotics for the disabled is a largely untapped field. I performed a few searches but came up empty. Thank you in advance for your replies.
stelmobarry
— Edited
8 Participants
But it needs to be triggered remotely that's the most important part to be completely remote
Further details on this circuit
Something along these lines. This one even allows the EZ-B to turn itself off. This is just an example, there are other circuits which could also be used. You can also have a remote RF controlled switching circuit run along side it to simulate the push button for remote operation.
Hello I found a Simple RF Receiver that should be small enough to fit into most any robot just use a small transistor on the output should do the of a simple remote power switch
That is really slick @Wolfie. Of course the question that comes up is how much power is the receiver drawing, and is it any less than just leaving the EZ-B on (for v3, almost certainly, but v4 goes into low power mode when ARC is not connected). I am sure there will be uses for this in any event. Cheap enough I will probably oder one just to play with.
