Lewansoul Servo icon Lewansoul Servo — Control LewanSoul LX-16A servos via ARC (EZ-B v4/IoTiny): assign virtual ports, read positions, set speeds, and enable continuous rotation. Try it →
Hi DJ, I understand from communication with your sales department that the range is 10 -20 meters depending on the antennae in laptop bluetooth. In on of your forums you mention 50 meters. For my project will need about 30 meters of range. Will I be able to get this with a good bluetooth dongle (class 1)? https://www.gridconnect.com/bluetooth-usb.html?utm_source=google&utm_medium=cpc&utm_campaign=North+America&utm_term=bluetooth+usb+dongle+b&gclid=CL6dmuuDgK0CFQSFhwodwGurRg Or do I need to have you quote me on the xbee / ez-robot setup?
Thank-you
Netherlands
@ jstarne1 Did the exact same thing:P. But I removed the BT and control it via USB.
@ TopView I'm using an Asus eee pc 900hd, its an antique:P, but it works and is small.
