Ultrasonic Distance icon Ultrasonic Distance — Displays HC-SR04 ultrasonic distance readings in ARC; scriptable via GetPing(), pausable, sets a variable with multiplier, optional NMS output Try it →
France
Question On Ezscript
Hi
I'm new with EZ Scripting is it possible to open in a script a plugin control window.
I have tested ShowControl("Synbot Plugin")
Script is executing without any error but control is not showing
I test also ShowControl("Benchmark") and other controls
and it is the same ...
Thanks for your help
Sorry It's closed and resolved , cause I don't use it in a mobile interface.
I Will do in another way
Regards
There is no way to add an object using a script. Showcontrol (and close control) are used in the Mobil Interface builder to show or hide a (normally desktop) control in the interface.
From the script help:
ShowControl( ControlName )
Used for mobile devices and the Interface Builder only, this command will open the specified control into the foreground.
Example: ShowControl("Wii Remote")
CloseControl( )
Used for mobile devices and the Interface Builder only, this command will close the current control, the same as pressing the BACK button on your device.
Example: CloseControl()
Ok thanks for pour help
