Custom Movement Panel V2 icon Custom Movement Panel V2 — Custom Movement V2 panel for ARC: scripts for F/R/L, Reverse, roll left/right, up/down with speed mapping to PWM for drones, mecanum & custom drives Try it →
Play Audio Through EZB Hardware
Is it possible to play an audio file through the EZB? I don't want to use the SoundBoardEZB robot skill because the audio files are numerous and changeable. The ARC command below plays audio on the controlling PC rather than on the EZB:
PlayAudio(filename)
For context: I'm running ARC on a PC that is connected to an EZB controller. I want the audio to be played by the EZB/hardware side instead of the PC.
Audio File Out EZB by Synthiam Inc
Stream MP3 or WAV files from your PC to the primary EZ-B speaker for robot audio playback, alerts, music, and voice clips.
It would be good if I could use:
controlCommand("Output Audio from EZ-B", "c:\\Music\\Filename.wav")
Yes - Audio File Out EZB is the right ARC skill for this.
It plays MP3 or WAV files out of the EZ-B’s speaker, rather than the PC’s sound card. Since your files are numerous and changeable, this is a better fit than a fixed soundboard setup.
How to use it
  1. Add Audio File Out EZB to your ARC project
  2. Make sure the EZ-B is connected
  3. Use a script or ControlCommand like:
ControlCommand("Audio File Out EZB", "Play", "c:\\Music\\Filename.wav");
Useful control commands
  • Play - plays the file
  • Stop - stops playback
  • IsPlaying - checks whether audio is currently playing
Example:
while (ControlCommand("Audio File Out EZB", "IsPlaying")) {
  sleep(100);
print("Playback finished");
Notes
  • Use the full file path
  • Supports .wav and .mp3 only
  • If the file doesn’t exist or isn’t supported, the skill will log the error
Skill page: https://synthiam.com/Support/Skills/Audio/Audio-File-Out-EZB?id=23351
If you want, I can also show you how to build a simple file picker / playlist script in ARC so you can choose any audio file dynamically.
